06-18-2021, 08:10 AM | #1 |
Rep 515
MST intake on convertible question
Hello, It looks like unlike on the coupe, the convertible have extra bracing in the engine bay passing slightly over the intake spot. Upon removing that and installing the MST intake, the bracing can only be tightened with bolt in 2 area instead of the original 4..
Can I just delete that and get a strut brace as replacement for structural rigidity? Attachment 2630097 |
06-18-2021, 09:05 AM | #2 | |
Rep 2,760
More involved answer requires the new strut brace to attach to the OEM bolt points. There is specific engineering into the rigidity and you don't want to mess with it. Say you replace it with a more robust member; then you get into an accident. That member will yield at a higher point and the design to push the eng and tranny to the ground will not have the same vectored forces and may be catastrophic to the occupants. That aside, could you modify the intake for the strut to bolt down? Maybe there is a replacement strut that allows for the fit. |
06-18-2021, 09:22 AM | #3 | |
Rep 515
Doubt there is another replacement strut that will allows for the fit unless its custom made to fit. I wonder then if I should try running the intake without the top cover? lots of other intake doesnt have that |
06-18-2021, 09:27 AM | #4 | |
Rep 2,760
