Amplifier Upgrade? (Audiotec-Fischer Match UP 7BMW) for iM240 |
05-17-2021, 11:44 AM | #1 |
Rep 42
Hey BMW Addicts,
After speaking with a local car audio shop I got recommended upgrading the stock amplifier to Audiotec-Fischer Match UP 7BMW. Thoughts? It is on the pricier end but is it worth it? It's sad to say my 2011 Nissan Maxima's audio system (Bose) bumps more than my M240 Is there any other recommendations? I am going for louder but clean sound with improved bass. |
05-17-2021, 12:39 PM | #2 |
Rep 2,133
You could achieve better tonal clarity + smooth out the harsh highs by changing out the fronts.
In order to get more bass out of the underseat woofers, you definitely need more power fed to either the stock woofers, or change those out also w/ an aftermarket solution. Installing a dedicated subwoofer in the trunk will also make a huge difference. That said, if you're close to Brooklyn, NY, I'd check out Integral Audio. I've ordered their Soundstage DSP for the 2er, and I'm impressed with the improvement. Will post full review pretty soon. |
05-18-2021, 08:32 AM | #3 |
Rep 1,264
I installed the Audiotec-Fischer (AF) MATCH 7UP BMW amp in my M240i. The amp is, as you know, highly tunable. So, read and understand the process for setting up the amp. There are several videos on how to configure the amp. The biggest improvement is the installation of either an AF Bluetooth or USB module in the amp. These allow you to digitally stream music from your phone or other device (I use a FiiO M3 Pro) to the amp. The amp has a high quality digital to analog converter (DAC). The difference-using the head unit's DAC vs using the amp's DAC-is amazing.
05-18-2021, 10:20 AM | #4 | |
Rep 42
I was actually born and raised in Brooklyn. Love the car scene out there. Can you share how much you spent on your specific set up? Soundstage DSP is showing to be $4,000. Would love to check out your full review! Any recommendations for a less pricy soultion to better sound? Will switching the stock amplifier for the MATCH 7 be worth it? |
05-18-2021, 10:25 AM | #5 | |
Rep 42
05-18-2021, 02:36 PM | #6 | |
Rep 2,133
I wish I was closer so I could take a tour in their facility. I just posted a review of the Soundstage DSP. Check it out! Will send you PM with more details. |
05-20-2021, 07:21 AM | #7 | |
Rep 26
Here is a link to the product page: https://integralaudio.com/soundstage...ies-coupe.html Here is the review thread that swayed me into trying it out: https://www.2addicts.com/forums/show....php?t=1754715 |
05-20-2021, 08:53 AM | #8 |
Rep 1,264
My first move was to replace the front components speakers with Eton components. Simply plugnplay. I then replaced the rear speakers with JL 2-way speakers I then installed the AF amp and tuned it. Major improvement. Next, I installed the AF USB module (my iPhone didn't play well with the AF BT module) and ran a 15 cable from the console to the amp. That made a huge difference. My latest mod replaced the USB cable with a USB cable with a USB-C and USB-B mini connectors. I'm using a Fiio M3 Pro with a digital output. Playing FLAC (lossless) music is incredible.
