Burger Tuning (BMS) Heat Exchanger for BMW B48 / B58 Intercooler System *NEW PRODUCT* |
05-04-2021, 08:37 AM | #1 |
Rep 190,805
Increase your B48/B58 BMW cooling capacity for better performance This B48/B58 platform intercooler upgrade is a high-quality replacement heat exchanger dramatically improves turbo/inlet air cooling by providing double the cooling surface area and over three times the fluid volume compared to the factory cooler. The benefits are most noticed during back to back runs at higher boost levels where the factory cooling capacity can be overwhelmed resulting in ignition timing pull and reduced turbo efficiency. Direct bolt-in installation. BMW 1 Series • 2016-2019 B58 M140 • 2016-2019 B48 120i, 125i BMW 2 Series • 2017+ F22 F23 B58 240i/iX • 2017+ F22 F23 B48 230i/iX • 2017+ F22 F23 B48 225i/iX • 2017+ F22 F23 B46 220i/iX BMW 3 Series • 2016+ F30 B58 340i/340iX • 2016+ F30 B48 330i/330iX/330e • 2016+ F30 B48 325i/325iX • 2016+ F30 B46 320i/320iX • 2016+ F30 B46 318i/318iX BMW 4 Series • 2016+ F32 F33 F36 B58 440i/440iX • 2016+ F32 F33 F36 B48 430i/430iX • 2016+ F32 F33 F36 B48 425i/425iX • 2016+ F32 F33 F36 B46 420i/420iX
05-08-2021, 09:46 AM | #2 | |
Rep 487
05-08-2021, 09:50 AM | #3 |
Rep 190,805
if you had to choose one, I would go with wmi
05-08-2021, 09:56 AM | #4 |
Rep 487
05-08-2021, 09:57 AM | #5 |
Rep 190,805
you need a retune after methanol injection, you do not need a return after the heat exchanger
05-08-2021, 10:16 AM | #6 |
Rep 487
So this means if I run out of wmi tank on the road, my engine is compromised and I cant do wot right?
05-11-2021, 08:37 AM | #7 |
Rep 190,805
Most setups have a failsafe that will check for meth and limit power once you are out
