2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Exhaust valves
      03-09-2017, 07:27 PM   #1
icycoldd
Drives: AW M240i
Exhaust valves
Does the M235i unplugged valve trick work on the 240i?
      03-10-2017, 02:32 AM   #2
Shayan55
Shayan55's Avatar
Drives: F90 M5
2105 BMW M235I  [0.00]
Try it and let everyone here know
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct
Hmu on Ig: @n55_shayan
WolfGTI716.00
      03-14-2017, 01:55 PM   #3
42395_skyline
42395_skyline's Avatar
Drives: 2017 M240i
Just open the valve and unplug it. Tape up the connectors and zip tie it out the way. Takes 5 minutes I did it asap when getting my car.
      03-14-2017, 02:38 PM   #4
AlexM240i
Drives: M240i
And what's the result ???
      03-14-2017, 03:47 PM   #5
42395_skyline
Drives: 2017 M240i
It sounds like you are in sport mode all the time.
AlexM240i101.50
mc3456389.50
      03-14-2017, 06:05 PM   #6
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
I thought doing so causes a silent code on the car that the dealer will read next time you bring it in? The flap on my M235i exhaust has started rattling and has been replaced by the dealer two times already. Wish I could just remove the stupid flap altogether.
      03-17-2017, 09:58 AM   #7
wntrsnowg
Drives: 2016 M235i
Not necessarily. Sport mode also pipes more sound through the speakers
      03-19-2017, 11:32 PM   #8
42395_skyline
Drives: 2017 M240i
That's true but I have coded ASD off and forgot about it.
      03-19-2017, 11:33 PM   #9
42395_skyline
Drives: 2017 M240i
Not sure if true but the dealer won't care. My dealer recommended it the day I went to pick up the car and I recently took it in to another BMW dealer and they didn't mention anything.
You could delete the valve BTW. I'll be getting new tips welded and planning on having them remove the valve all together.
      03-20-2017, 07:21 PM   #10
evancross
evancross's Avatar
Drives: 2017 M240i 6MT
From my understanding and after testing, the vehicle will open up this valve once the vehicle is warm. That being said, I have heard all kinds of different rumors.
      04-24-2017, 12:55 AM   #11
doccyber
doccyber's Avatar
Drives: %D0%97%D0%B0%D1%81%D1%82%D0%B0
And what's the purpose of the valve anyway? Is it just a gimmick?
      04-29-2017, 10:22 PM   #12
kohlzor
Drives: 2017 M240xi
While the car is running?
      04-30-2017, 07:41 AM   #13
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
I suspect its actually emissions related. It snaps closed immediately on a cold start of the engine. To increase back pressure maybe? It opens approximately 2 minutes later, so there must be a reason why.
      05-02-2017, 11:18 PM   #14
42395_skyline
Drives: 2017 M240i
Run the car to open the valve, once it's open turn off the car and you can do everything with the car off.
kohlzor46.50
      02-17-2021, 04:07 PM   #15
Ajowhan
Drives: m240i 'vert
I believe its mostly for the sounds. A car that roar during spirited driving and yet quiet for neighbors!
      02-19-2021, 06:45 AM   #16
cowymo
Drives: 2021 BMW M440i XD
What I did was use BimmerLink and coded it Open. When you first start the car, the valve remains close until the engine is slightly warmer and the valve will stay open after. I like it.
      03-14-2021, 02:05 PM   #17
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
I guess I will try Bimmerlink and code it open. Mine never has opened that I can tell. Checked after the car was full temp - it was closed at idle, went into Sport mode - it was closed at idle. Tried Sport + - it was closed at idle.
      04-26-2021, 09:10 AM   #18
cowymo
I just checked yesterday, apparently Bimmercode won't leave the exhaust valve open permanently. You have to use Bimmercode to open the valve, and physically unplug the connection at the valve. That's what I did yesterday, so far no CEL.
      04-26-2021, 09:36 AM   #19
MassNerd
MassNerd's Avatar
Drives: 2019 M240i Coupe RWD
It's to be nice to your neighbors. Ford has this option on the Mustang as well. Valve closed, exhaust is quieter.
      04-26-2021, 09:40 AM   #20
spidy512
Drives: 2015 f80 M3
2015 BMW M3  [0.00]
Correct. It will close on cold star and open 2 or so minutes later. So it does keep it open, just after warm up.
josh
      05-03-2021, 07:41 PM   #21
Timboston
Timboston's Avatar
Drives: BMW M240i convertible xdrive
I had pulled the clip connecting the flap shaft to the servo and wired the flap open. It still wasn't loud enough so I replaced the muffler with the M Performance exhaust. No flap, plenty loud and could care less what the neighbors think ;-)
MassNerd171.00
      05-10-2021, 01:24 PM   #22
RGM330i
RGM330i's Avatar
88
Drives: 2024 BMW 228i Gran Coupe
Just installed the M Performance Exhaust on my M 240i. I used the instructions for the Dinan installation to move the valve actuator to another location and left it connected. It still, technically, operates so no opportunity for any codes or faults. I did this exact same thing when I put a Dinan on my 2018 330i. I ran it this way for two years with 0 issues.
