10-23-2020, 01:04 PM | #1 |
Rep 1,450
Help.... coolant loss
My 2018 LCi M240i has been using coolant for over a year and it's been to dealership twice and pressure tested and no leaks anywhere. I have Just tested its consumption over 1000 miles and is used 20ml in the small reservoir and 120ml in the large reservoir. A total of 140ml in 1000 miles..... that's 1.4 litres in 10,000miles !!! It's booked back in with BMW but I'm worried they will say it's normal again and no fault found . That amount of coolant loss is definitely not normal. Anyone got any ideas as dealership say they have never seen this issue before. I can only think the engine is using it. Turbo issue around the seals for water cooling maybe? I don't have any emulsification in the oil filler cap so it's not getting past the head gasket into an oil feed
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
10-30-2020, 10:59 AM | #2 | |
Rep 216
10-30-2020, 12:08 PM | #3 | |
Rep 3,506
The issue has been discussed at length on BabyBMW.net – this is the principal thread: https://www.babybmw.net/viewtopic.php?f=74&t=110573.
10-30-2020, 12:12 PM | #4 | |
Rep 9,708
In my experience (engine - large rear tank), if you fill to the full mark when cold, the system will vent some coolant until it's back down around the low fill mark. It will keep doing this no matter how many times you keep topping it up. However, if you're saying when you don't top up it keeps disappearing and you get low level alarm then for sure you have an active (abnormal) coolant loss. |
10-30-2020, 12:26 PM | #5 | ||
Rep 1,450
10-30-2020, 12:27 PM | #6 | ||
Rep 1,450
10-30-2020, 01:25 PM | #7 | |||
Rep 9,708
10-30-2020, 01:27 PM | #8 | ||||
Rep 1,450
10-30-2020, 03:13 PM | #9 | |
Rep 3,506
Upper Grille Opening After Rock Guard Installation Lower Grille Opening After Rock Guard Installation
10-30-2020, 03:18 PM | #10 | ||
Rep 1,450
10-30-2020, 03:19 PM | #11 | |||
Rep 1,450
10-30-2020, 03:21 PM | #12 | ||
Rep 3,506
My dealer must follow the 200ml above MAX direction, as that's pretty much how it's come back after the two coolant changes I've had. * Mike is the Technical Editor for the BMW Car Club of America's Roundel Magazine. His rationale is based upon the years (decades?) of BMW cooling system issues. Mike's thinking is that somewhat less coolant (but not too little!) will result in less pressure in the system, followed by fewer cooling system failures.
10-30-2020, 03:22 PM | #13 |
Rep 3,506
No, no...forget the mesh in front; what you're meant to look at is the radiator-like panel behind it. That's the rock guard, both top and bottom. Sorry for the confusion!
10-30-2020, 03:24 PM | #14 | |
Rep 1,450
10-30-2020, 03:25 PM | #15 | |
Rep 3,506
But, I did get another coolant change out of it!
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 10-30-2020 at 03:30 PM.. |
10-30-2020, 03:28 PM | #16 |
Rep 1,450
I have found black aluminium mesh and some "U" profile rubber edging that I am hoping I can wrap around the outside edge to make it neat and then a few black cable ties to fit it to the plastic oem grille. The lower side ones I hope to be able to remove and the kidney grilles cone out easy anyway
