10-19-2015, 01:32 PM | #969 |
Rep 87
This is actually a nice default feature. It starts to load navigation when car is unlocked, so I usually unlock the car while walking through the parking lot. By the time I turn the car on, both navigation and traffic info are loaded (or almost loaded).
10-20-2015, 07:56 AM | #971 |
Rep 55
The default for that is 0F, what should the setting be changed to Pikcachu?
Sorry, ignore me; just seen the setting on the cheat sheet. Doesn't change anything though as far as I can tell so a no go...
BMW M240i Sport Auto, Mineral White / Coral Red, Professional Navigation, Driver Comfort Package, Sun Protection Package, Harmon-Kardon Loudspeaker System, Sunroof, Mirror Package, Heated Seats, 405M Wheels, M Performance Parts
10-20-2015, 09:53 AM | #972 |
Rep 5,262
supposedly it will make the sensors work all the time... maybe you need some of the other PDC variables to be changed.... the problem with this would be everytime you get to a light, it will beep cause of the car in front
10-30-2015, 04:13 PM | #974 |
Rep 12
pikcachu Better to ask here than a necro'd thread. I will be taking delivery of a new M235i (RWD) in approx 3 weeks. I have now found out after order of the 130 vs 155 depending on the tire.
Since my car is coming with all seasons, I will be locked at 130mph for tire safety reasons. However, my intentions were never to keep the all seasons, I just wanted the darker rim option. Is it realistic to think that I will be able to modify the 130 mph limit to 155, without a burger tune or similar? |
10-30-2015, 04:18 PM | #975 | |
Rep 5,262
that's what I know |
10-30-2015, 04:23 PM | #976 | |
Rep 12
So to even attempt this, I would need to arrive at my dealership for pickup with a cable and laptop in hand ready to try and program? I am thinking, if, down the road, BMW issues a mandatory software update for our vehicles will we have an issue? If the VIN ID of a car (like mine, 130 mph) leaves the motherland knowing it was last a 130mph car, would an update from my dealership not overwrite any potential changes I may have made within the first 10 hours? Do we have any instances of 840 being added successfully after delivery? (I read many threads of suspicions of GPS monitoring etc...) (you don't happen to live in the SE Michigan area, do you?) P.S. I would have PM'd all this to you, but I am new on the forum and am waiting my 1 hour for verification. Apologies, not trying to hi-jack. Last edited by cybrnook; 10-30-2015 at 04:29 PM.. |
10-30-2015, 04:38 PM | #977 | |
Rep 5,262
You might need a charger to keep the voltage as you can't code the DME with the engine running... not sure if it's worth the trouble to do Not sure, worst case it goes back to 130 if the dealer flashes the car... I remember reading on the F30 forum someone was able to do it.. |
10-30-2015, 04:41 PM | #978 |
Rep 12
Thanks for taking the time. I think I am going to pass on the 155 limit. Thinking about it, I assume you mean 10 hours within the FIRST time the motor has run (not total run time). So I would need to do a ED. I will not be doing this.....
Only well. It's not that I would ever drive over 130 (Or even 130). Just part of me being able to bang on my chest Thanks again! |
10-30-2015, 08:15 PM | #979 | |
Rep 5,262
10-31-2015, 01:53 PM | #980 | |
Rep 199
What changed with BC_MOTORTEMP_ENABLE is that temperature icon changed (previously it was a motor, now it's regular temperature one) and there is now a cursor. BUT cursor stays on the left unfortunately and there is no OK nor LOW displayed... While my car was serviced two weeks ago, dealer gave me a 216d Active Tourer and BC_MOTORTEMP_ENABLE was working OK... It has entry_nav and low combi display. Motor temperature was displayed properly on combi (with moving cursor and LOW/OK message depending on motor temperature). There was also a CID secondary Sport Menu (on top of power/torque one) in which it was indicated that motor temperature was Normal... M2 press release documents shows a functionnal BC_MOTORTEMP_ENABLE... |
11-06-2015, 12:20 PM | #981 | |
Rep 818
11-12-2015, 09:06 PM | #982 |
Rep 554
Dumb question: Can anyone tell me what the BC is?
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
11-18-2015, 01:56 PM | #985 | |
Rep 5,262
Animation should work for all screens |
11-18-2015, 06:51 PM | #986 | |
Rep 349
Getting coded this weekend so I've been thinking of what to get:
11-19-2015, 06:54 PM | #987 |
Rep 4
Token locator
I found some pretty useful information in the instructions that came with my new BMW ENET (Ethernet to OBD) Interface Cable.
Writing this as the obligatory initial post and kickstart my membership on the forums and gather further coding instructions. Since I have the OBDII cable I'm requesting directions to the most current SW and the “Fully Functional” version of the ESYS Launcher Pro appropriate for a 2015 228i. Thanks in advance. Cheers, Mac |
11-19-2015, 07:59 PM | #988 | |
Rep 5,262
11-19-2015, 09:04 PM | #989 | |
General
10445
Rep 40,789
Drives: 2018 Alpina B6 650ix GC
E-Sys Launcher Pro can only be obtained via the Developer (TM) though.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
