09-28-2021, 11:25 AM | #1 |
Rep 210
FS: F/R SPL sway bar end links F30, F32, F22
Used for 10k miles and willing to separate. $450 new from BimmerWorld. Adjustable sway bar links allow you to remove pre-load on the rear sway bar. Pre-load happens during installation and setup which causes tension in the bar. With the adjustable links you can install one side and then adjust the length on the other side to match. Adjustable links can also be used to move the sway bar to better clear other components, a common issue with larger sway bars. Designed for track/racing use only. Use of solid and spherical bushings will have more noise and harshness than any other material and are not recommended for street use. SPL racing suspension parts are designed and manufactured in the USA from premium materials. SPL has a foundation in road racing, time trials, and drift competition which require precise suspension and alignment settings that can only come from spherical and solid mounts. Their parts are made with high-grade aluminum and titanium and use CNC machining and advanced production techniques to achieve to tight tolerances and light weight. FK Spherical Bearings include a Teflon inner liner for quieter and longer service life. SPL Parts have a limited one year warranty.
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
