2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Rpm drop then big rpm increase on cold start
      07-03-2021, 01:42 AM   #1
Chill Dana
Chill Dana
Chill Dana's Avatar
This just started yesterday and happened again today. On cold start the car starts right up, but then about a second later the rpms drop to around 400 and it seems like it's about to die then roughly 2 seconds later it shoots up to around 2,500, and then about 3 seconds later returns to normal cold idle. I have a Vrsf catless down pipe and Vrsf chargepipe, no tune yet but, I've had them for about six weeks now and this issue just started yesterday. Any help on this issue would be greatly appreciated. Thank you. Forgot to mention it's a '15 M235i
      07-03-2021, 01:52 AM   #2
zombem235
zombem235's Avatar
16
Drives: 2015 m235i
Mine does the same thing. Same modz. Been trying to figure it out for awhile. Curious to what others think. Following
      07-03-2021, 10:32 AM   #3
MarcoZandrini
Drives: 2018 M240i
Scan the engine computer (DME in BMWSpeak) for codes. The Service Engine Soon (SES) light is on only when an emission related code is present.
      07-22-2021, 03:27 PM   #4
XutvJet
On a fully warmed up engine and the car RUNNING while in park/neutral, disconnect the MAF sensor and let the car run for about 10 minutes. Turn the car off and reconnect the sensor. On the next cold start, the weird almost stall cold start issue will very likely be gone.
My M235 did this recently and this was the fix. It's been the fix for other N55 others too.
      08-07-2021, 10:20 AM   #5
zombem235
zombem235's Avatar
16
Drives: 2015 m235i
Tried this didn't work. Anybody else have any luck with something else? It has even died on me if I don't let it sit for a few minutes
      09-28-2021, 01:38 AM   #6
Awn
Newbie
Awn's Avatar
Saudi Arabia
Drives: BMW M235i
it happened with me when i pulled the gear to Reverse then back to N when cold starting, never gona do this again.
Estoril Blue - Coral Red
