09-21-2019, 10:31 PM | #1 |
Rep 22
Need help! Really bad e30 mixture problem
Hello. This is my first post and I'm having a major issue. I just got a e30 map from a custom tuner for e30. And I might have put a little bit too much ethanol but I did talk to the guys at PTF and they said the car should adjust and doesn't need to be spot on( I'm at 36%
Mix) the problem is whenever I'm WOT after the first shift my car starts crackling kind of like anti lag does anyone know what is causing this? Also the car doesn't feel any fast and feels like it's struggling. I wanna datalog for my tuner but I'm scared I'll break something if it's serious |
09-22-2019, 04:58 AM | #2 | |
Rep 170
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
j2dad5389372.00 |
09-22-2019, 05:02 AM | #3 | ||
Rep 22
here's the sound on video |
09-22-2019, 05:16 AM | #4 | |||
Rep 170
E series N55s with the old rotary hpfp can take more than E30 and handle it well. The EWG N55s with the piston fuel pump max out at E30 and although people are kicking out tunes for them - if you log, you'll see that the pump is crashing up to 1000psi below target. So not all info on the internet about the N55 and Ethanol pertains to both variants of the platform. I could only run E25 max before my pump started crashing. At E30 I could feel the car stumbling and my crashes were bad. Once I upgraded to the B58 hpfp that all went away and I'm good up to E40. If you're on E36 your pump is probably fighting for its life. I'd get your fuel back down before WOTing it again.
09-22-2019, 05:21 AM | #5 | ||||
Rep 22
09-25-2019, 10:43 PM | #6 | |||||
Rep 12
09-26-2019, 04:49 AM | #7 | ||||||
Rep 22
09-13-2020, 12:12 PM | #8 | ||||
Rep 325
09-14-2020, 10:48 AM | #9 |
Rep 1,219
Drives: 2015 M235ix
Every time I read a thread like this, I thank my lucky stars that I have never had any interest in mods. I like my cars to stay the way God (BMW) intended.
