09-18-2018, 12:09 PM | #1 |
Rep 3
Aftermarket Winter rims for 2015 235i x drive
I found these rims that are 18x8 all around. The happen to also come with winter rubber. The size is however 235/40/18.......will this rub in the front? (As most are aware fronts for summer are 225/40/18 7.5 and 245/35/18 8"rear OEM) tires will probably need to be changed after the up coming winter, then I can go to a 225/40/18. But as offered these are 8' inches width all around. But will it work?
09-18-2018, 12:15 PM | #2 |
3612
Rep 3,578
If the wheel offset (ET) is in the range of 40 to 45mm they should fit. I'm running 225/45-18 (23mm larger diameter than stock) winter tyres on 18x8 ET45 wheels without any rubbing.
09-18-2018, 01:24 PM | #3 |
Rep 69
Drives: 2014 M235i AW
I have 18x8.5 - 45 offset wheels up front with 235/40/18 tires (PS4's) and no problems.
2014 BMW M235i AW
1998 Porsche 911 2007 Mercedes E350 Wagon 2001 Toyota MR2 1977 Lancia Montecarlo 2002 Acura RSX Type S |
