2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Trunk fails to engage.
      09-15-2018, 12:04 PM   #1
farshman
farshman's Avatar
Drives: 2015 228xi
Addicts,
Problem ran into this weekend thought I'd share for future observers.
Identification: Was driving when I noticed the ! sign displayed in the dash and realized it was the trunk open as I was driving, so I exited quickly at the stoplight, opened the trunk and closed it. When I arrived home to pop the trunk the problem happened.
Problem: Trunk cannot be opened. Instead the trunk mechanism makes a whirring or clicking sound attempting to be opened.
Troubleshooting: Behavior exists no matter what method of trying to open the trunk is attempted (key, driver-side open switch, manual release on rear of vehicle).
Investigation: Cannot enter into the trunk by any means including the seats as they can only be released from within the trunk and mine were locked. Local BMW dealer could not do anything in a quick fashion so I have made an appt for 2 days from now to see if there is an actuator failure.
Further evidence of anomaly:
https://streamable.com/58km8 (my video)
https://www.2addicts.com/forums/show....php?t=1385145
https://www.2addicts.com/forums/show....php?t=1533403
https://www.2addicts.com/forums/show....php?t=1201443
Vehicle:
2015 BMW 228xi (~45000 miles)
I've tried the brute force method with no resolution but will keep attempting. (laterally, up/down, tried pushing down with force to re-engage and pop up)
Update with Resolution:
Dealership confirmed I did have a faulty actuator, confirmed the failure through hardware testing. Part was ordered (had one month left on warranty...crazy) and received a loaner car (free of charge because "the dealer would not have had to order it if they had the part in stock" and then they installed and we were ready to go!
This was the first time the dealer had seen this actuator fail. They actually did what Zwei below mentioned, took a long thin tool to go inbetween the rear seats...but at this point I'm not sure if they used that to pop the rear seat or pull the internal handle.
      09-17-2018, 09:08 AM   #2
Zwei
Drives: 2014 M235i AW
1998 Porsche 911  [0.00]
2014 BMW M235i  [0.00]
I had the same problem with my Acura. A piece of plastic had fallen into the lock assembly. The solenoid on the latch was not powerful enough to overcome the plastic debris and open the latch. Once the debris was removed the latch worked as if new. This is a fairly common problem. Latches attract crud. The whirring noise means most of the latch functions are being performed.
You will need to pop the rear seats down to get in there and fix it. To do that you use the gap between the seats to insert something that you can pop a seat latch with. It would be helpful to get a similar car and measure the direction and distance to the latch release lever from the gap.
Good luck!
2014 BMW M235i AW
1998 Porsche 911
2007 Mercedes E350 Wagon 2001 Toyota MR2
1977 Lancia Montecarlo 2002 Acura RSX Type S
      09-18-2018, 06:01 AM   #3
Heitzer
Drives: M235i; BMW S1000RR
Had the same problem with the trunk.
Dealer replaced the trunk lid lock. Under extended warranty fortunately .
      09-18-2018, 09:22 AM   #4
M235ForNow
Drives: '16 M235i
Same (almost) issue. Caused by a leather strap falling across the latch just as trunk was closing. Was compressible enough that the trunk closed but the leather buggered up the unlatch mechanism. In my case I was able to push down on the trunk and then lift up while hitting unlock to finally get it to release. Didn't do any favors to the leather strap.
      09-19-2018, 08:40 PM   #5
farshman
farshman's Avatar
Drives: 2015 228xi
Updated initial post, thanks for replies!
