05-02-2021, 01:37 AM | #1 |
Rep 1
Clutch pedal too far for short people
I'm 5 foot 6 inches tall, and I find the clutch pedal to be really far away. When I adjust the seat close enough for me to comfortably press the clutch all the way in, the steering wheel is too close to me. I adjusted the steering wheel all the way back.
I don't recall ever experiencing this on another manual car before. I don't think I'm *that* short. Are there any other short-er people driving manual 2 series here? Last edited by theinvisible; 05-03-2021 at 12:27 AM.. |
05-02-2021, 06:31 AM | #2 |
Rep 88
I can't chime in really cause I'm tall but it's a common complaint that the clutch pedal travel is too long on this car.
A lot of members use a clutch stop to shorten it. Maybe that's something you can try |
05-02-2021, 07:35 AM | #3 |
Rep 1,219
Drives: 2015 M235ix
How far back do you keep your arms, OP?
Do you keep the seat back close to vertical? Many people sit at too great an angle. BMW recommends that you keep the seat back close to vertical and be able to rest your wrists comfortably on the top of the steering wheel. That feels too close for some people, but it gives you better steering control and you will get used to it pretty quickly. Try it and see if it helps with the leg length. And 5'6" is not really short. Many people are shorter, including a large fraction of women. |
05-02-2021, 08:03 AM | #4 |
Rep 744
Advice on seating position:
makrop151.00 abraxas61310.00 |
05-02-2021, 09:12 AM | #5 |
Rep 6,031
Humorous play between your height and screen name!
Check out the below. This could make you much more comfortable without compromising safety by being too close to the wheel/air bag hub. https://www.discovermymobility.com/s...BoCOj0QAvD_BwE Last edited by Sportstick; 05-02-2021 at 09:41 AM.. |
05-02-2021, 09:59 AM | #6 |
Rep 148
05-05-2021, 02:05 PM | #7 |
Rep 45
Drives: 2016 M235i F23
I added pedal pads and they give you some extra space
05-05-2021, 04:03 PM | #8 |
Rep 5,372
You might want to try the Ultimate Clutch Pedal. It lowers the resting point of the clutch pedal to just below the brake pedal, basically removing about 1" of upward resting space. It also makes the clutch take-up distance a bit less and you can adjust it for firmness as well.
It seems a bit counter intuitive to actually lower the clutch pedal to address your issue, but perhaps it would help you because it could get the pedal more even so you don't have so much leg lift coming off the pedal and the shorter take-up might help as well. https://www.turnermotorsport.com/p-1...hoCwRcQAvD_BwE
05-05-2021, 04:21 PM | #9 |
Rep 57
I’m with you on this…
OP, I’m only 5’6” as well and the clutch pedal does seem very far away. It took a little getting used to sitting this close, because to depress the pedal all the way, I have to move the seat up pretty far. I had this same issue on my Corvette. In Vette, the solution was to buy a pedal extender. Yep, those exist in the Corvette world and I looked for a solution for my 2. I’m glad you posted this because I just ordered the Burger Tuning part. I didn’t even know it was a thing. I’ll try that and maybe be able to push my seat back ever so slightly.
I do find that in my current seating position, I have full control of the car. I’m used to sitting upright because my last 2 cars were the Corvette and an ND Miata. Also, I learned proper seating position at the BMW driving school. If you haven’t had a chance to do that, I encourage you to do so. It’s a fun event and great learning experience. Anyway, glad that I’m not the only person to have this problem. |
05-05-2021, 04:51 PM | #10 |
Rep 243
Seat positioning is EVERYTHING in this car. @ 5 7 myself, it took me some time to find the perfect placement and even, to this day, find myself slightly adjusting depending on the shoes I wear.. Not impossible but yes, the clutch travel is wild in this car.
I jumped in my buddies '16 wrx and almost died. The travel is almost nonexistent. You can go from pressing all the way down to fully out position without even extending your leg, just foot action lol .
'15 235i - Moddedededed
05-07-2021, 02:05 PM | #11 |
Rep 527
At 5'6" I also had to make an adjustment. The problem is that the clutch and brake are not aligned. Easy fix was to attach a 3/4" thick wooden block to the pedal and reinstall the rubber pad. (had to make a groove in the wood to accommodate the rib around the pad)
Also I made aluminum risers for the driver's seat. (manual seat) 1 1/4" works out for me. BTW, 5' 6" is just about the average for all drivers in the US. We should be easily accommodated in any vehicle but seats are generally designed for the vertically challenged (those over 6'6") Folks under 5'0" must just be accustomed to peering thru the wheel. A couple of years ago I found myself in a rented Jeep. Had to borrow one of those huge cushions off the patio furniture to get comfortable. |
05-09-2021, 05:37 AM | #14 |
Rep 205
05-09-2021, 09:00 AM | #15 |
Rep 6,031
Quite a few people (don't mean to be sexist, but I've mostly observed among women) will "drape" their forearms down the face of the steering wheel rim instead of holding their arms out in front of them. This unfortunately reduces the distance to the hub. If you notice she is doing that, the first helpful step would be the seat adjustment to the point when her absolutely straight ahead arms land on the top of the rim at the watchband. Then, she can bend the elbows enough to bring the hands rearward to hold the rim.
05-13-2021, 05:14 PM | #16 |
Rep 57
I got my burger Motorsport part and installed it. OMG! What a difference it makes. I always thought there was way too much travel in the clutch, but wow, now the engagement is almost instant. It feels so much closer to where the clutch was in my corvette and Miata. My shifts are so much smoother and now I find it a joy.
As far as seating position? I moved the seat back slightly but I wouldn’t say it made that drastic of a difference. I will note that the clutch stop will not be for everyone. The clutch engagement is maybe 1” from the “floor” now. I love it, but I can see how some people would hate that. You can adjust it by using less spacers. I have all of them in there. |
espektor3.00 |
05-14-2021, 05:29 AM | #17 |
Rep 527
A caution with devices that shorten the travel of the pedal; you must be sure that the clutch fully engages and disengages. If it doesn't fully engage you can smoke the clutch disk and wear out the throwout bearing. OTOH if it doesn't fully disengage you can wear out the synchromesh and the gears might grind.
This is per my understanding of older clutches in other brands. BMW may be a little different. |
MLJR235116.50 |
05-14-2021, 08:03 AM | #18 |
Rep 6,990
Have you tried platform shoes?
05-14-2021, 10:07 AM | #19 | |
3626
Rep 3,593
dradernh4405.50 Sportstick4654.00 |
05-14-2021, 11:36 AM | #20 |
Rep 243
Almost any variation of Nike running shoes add some feet cushion for added reach
Converse, while comfy, will be on the other end of the spectrum with almost no heel cushion, so adjustment is almost always required.
05-14-2021, 12:14 PM | #21 | |
Rep 3,497
Nike claims the shoe's full-length carbon fiber plate(!) "provides a snappy sensation with each step", so engaging and disengaging the clutch is bound to be more exciting than ever before!
05-14-2021, 01:15 PM | #22 | |
Rep 57
For shoes? I wear vans most of the time. I find that when I wear thicker sole shoes, I can’t “feel” the clutch as well. I avoid those shoes when I’m driving. And my feet always feel like they are getting in the way of the pedals, getting caught on the floor mat, etc… |
