02-06-2018, 12:29 PM | #375 |
Rep 2
Here's my 235 with a set of silver 703's
Here's my 2016 235 with 8.5x18s in the front, 9.5x18s in rear. Stock 225s in the front, and 245s in the rear. Will probably replace with 235s in front and 255s in rear. Love these wheels. Here's a set on my e46 330Ci too...
02-08-2018, 08:31 AM | #376 |
Rep 120
Drives: 228i M Sport Pack
hey everybody.... i just realized everyone who has a 19X9.5 VMR wheels wearing 255/35/19 PSS tires dont have an issue with the rim extending past the tire.
My rims have suffered from rashes because they stick out about 0.5cm form the tire. ill upload photos soon, but i just thought its weird - maybe the tire was fitted wrong? |
02-09-2018, 12:49 PM | #377 | |
General
2050
Rep 25,989
VMR|Wheels | 714.442.7916 |
02-17-2018, 06:21 PM | #378 |
Rep 57
V804
Just replaced my M235i xDrive factory square setup, which was:
- 18x7.5 ET45 - 225/40/18 Pirelli Cinturato P7 all season run-flat - 12mm spacer front, 15mm rear Went with a square VMR setup: - VMR V804 | Hyper Silver - 18x8.0 ET42 - 235/40/18 Michelin Pilot Super Sport - Stock suspension and alignment - No modifications needed to fit, no rubbing noticed so far Really happy with the fitment, many thanks to Brandon at VMR for helping me with this setup! BTW: each stock wheel and tire was 45.4 pounds, the new VMR wheel and tire is 42 pounds. Dinan springs are on the way ... |
02-18-2018, 06:33 PM | #379 | ||
Rep 138
Looking to run 18" 710s on 225 255s |
02-19-2018, 12:17 AM | #380 | |||
Rep 5,874
Acalamito32129.50 |
02-19-2018, 12:21 AM | #381 | ||||
Rep 138
02-19-2018, 02:33 PM | #382 |
Rep 5,874
Acalamito32129.50 |
02-19-2018, 06:21 PM | #383 | |
Rep 138
02-19-2018, 10:24 PM | #384 |
Rep 58
I just pulled the trigger on V801 Mercury Black Metallic for my M235i, staggered setup 19x8.5 ET35 19x9.5 ET45. I plan on going with 235/255 Will I have issues with 235/35/19 tires (for the front) on stock suspension? I see most are on 225/35/19. Thanks!
02-20-2018, 02:54 AM | #385 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
You’ll be fine. I’m running 235/35/19 on 19x8.5et39 (4mm closer to the suspension than your setup) and have no rubbing issues every and my driveway is fairly steep (about 20 degrees up roughly)
blkdinanm312.50 |
02-20-2018, 08:46 AM | #386 | |
Rep 58
Thanks Joe240!
Current: //2015 BMW M235i //2016 C300 AMG
Past://2011 E92 ZCP M3 //2006 E90 330i //1997 DINAN Stage 3 e36 M3 //1997 e36 328i |
03-03-2018, 06:45 PM | #387 |
Rep 58
19" VMR v801 Mercury Black
I installed my VMR v801 wheels today. I'll post better pics when it stops raining.
- Wheel Size/Offset 19x9.5 et45, 19x8.5 et35 - Tire Size/Brand Hankook Ventus V12s 255/30/19 235/35/19 - Suspension Setup Stock - Camber/Alignment Specs None - Modifications to make fit (if necessary) None I ran into issues with my OEM BMW locks. The VMR log holes are small, the lock key gets stuck. Has anyone encountered this issue before?
Past://2011 E92 ZCP M3 //2006 E90 330i //1997 DINAN Stage 3 e36 M3 //1997 e36 328i Last edited by blkdinanm3; 04-25-2019 at 10:33 AM.. |
03-10-2018, 01:12 AM | #388 |
Rep 1
Brake Calipers Rubbing
Anyone here have had issues with brake calipers rubbing against the wheel barrel?
I bought a set of wheels 18x9.5 for the rear and my brake calipers are rubbing against the barrel of the wheel and it's creating a mess.. |
03-13-2018, 08:18 AM | #389 |
Rep 49
Does anyone run 265 in the rear on a 9.5" rim either 18s or 19s. I dont like the stretched tire look. Im on stock suspension and want to fill out the rim. Wasnt sure if there would be clearance issues.
I had 19s on my 335i, but on the 2er it seems like there isnt much tire between the pavement & rim. Any reports of bent rim issues? Sometimes just the transition from new to old pavement has a harsh lip id be concerned with tweaking wheels. Seems 235 front & 265 rear is the size needed to fill out the rim. |
03-13-2018, 02:52 PM | #390 | |
Rep 1,303
265/30/19 19x9.5et44 back pokes about 7mm or so, but looks fine on stock suspension I feel. Definitely room to go in though but hard finding a 9.5 with high offsets. That’s what configuration im running and I like it |
03-15-2018, 10:30 AM | #391 | ||
General
2050
Rep 25,989
03-15-2018, 10:35 AM | #392 | |
General
2050
Rep 25,989
We've heard this come up in the past, but this is the first we've heard of this issue on the V801, so thanks for letting us know! I would recommend a set of locks that comes with a thin walled socket. I would check out RAD Locks and Gorilla Locks. Shoot me a PM with some details of what's going on and I'll be happy to help diagnose the issue! Thanks!
03-22-2018, 11:00 AM | #394 |
General
2050
Rep 25,989
Thanks for posting your pictures! These will be great for customers who are looking for a square setup!
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram Last edited by VMRWheels; 03-26-2018 at 05:29 PM.. |
03-22-2018, 03:16 PM | #395 | |
Rep 93
Current: 2018 LBB M2
Gone but not forgotten: 2016 Alpine White 228 xDrive M Sport Performance Mods: JB4 | Bilstein B14 Coilovers Cosmetic Mods: Vorsteiner V-FF108 18x8.5 +35 Square | M Performance Diffuser |
VMRWheels2049.50 |
03-26-2018, 05:28 AM | #396 |
Rep 1,161
Ive just read the whole of this thread trying to get the best set up.
loads of information and pictures. this is probably the only thread you need in deciding what wheel/tyre fitments work on the F22. but I have one question I couldn't figure out. the Front wheels in a 19 x 8.5 et 40.........could I run a 235/35/19 tyre with the car lowered on Blistein B12 pro kit? lowering is not aggressive , maybe 15mm at most front and 20mm rear. for the rears ive concluded that a 19 x 9.5 et 45 will be fine running 255/30/19 tyre. just the fronts to decide if a 225 or 235 width would be best.
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
Tags |
9.5, fitment, v703, vmr, wheels |
