2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics ConnectedDrive : New Software update available 12/2014
      12-17-2014, 11:49 AM   #23
kd0t
Originally Posted by qballis View Post
Mine still doesn't refresh track info or art over Bluetooth for Spotify. Am I missing something??
Mine does after the update. But I did realize a bit worse music quality from Spotify on BT though..
      12-18-2014, 09:41 AM   #24
mazerrackham
mazerrackham's Avatar
13
Drives: i3, M235i
In my drives since the update the track info updates pretty consistently. There was one instance where it got stuck on the same song, but not even the time moved and switching from spotify to music didn't fix it. I ended up disabling/enabling bluetooth on my phone and then it started working correctly again.
      12-19-2014, 07:36 PM   #25
StephanieDiane
StephanieDiane's Avatar
Drives: 2015 M235i, 2017 M2
My car was built in Oct and when I picked it up last week the dealer said they updated everything.
It says there are two updates, but also notes the update is for vehicles produced from July 2012 to Feb 2014.
Confused.
      12-19-2014, 08:22 PM   #26
horsepower_and_hounds
Drives: BMW
Confused.
If you download the update to a USB, plug it in your car will tell you there are no compatable updates then I bet....you can't install one if it is not the newest
      12-20-2014, 04:29 PM   #27
Drives: BMW
I just did the update with UPD05062 and it updated to TH-002.039.062/MN-002.039.060. My build was 7/19/14
      12-21-2014, 09:17 AM   #28
mazerrackham
13
Drives: i3, M235i
Mine was also built in Oct 2014. The site showed two updates, one for cars from July 2012 to Feb 2014 and one for cars with more recent builds.
      12-21-2014, 09:52 AM   #29
Drives: BMW
Go check your version on the idrive you might just have passed the cu off. Or go here and type in the last 7 of your vin
http://www.bmw.com/com/en/owners/con...re_update.html
If it says there is no updates then you have the latest
      12-29-2014, 07:01 PM   #30
turnstile
Drives: 2012 BMW x3 35i
Same here. 3/2014 build so I used the first update download bin. Spotify over BT still does not change song/artist/artwork data after the first song played. I might try using the pre March bin update and see if that works. Did you ever have any luck in resolving this issue?
      12-29-2014, 07:02 PM   #31
qballis
Drives: G80 Comp xdrive
Same here. 3/2014 build so I used the first update download bin. Spotify over BT still does not change song/artist/artwork data after the first song played. I might try using the pre March bin update and see if it that works. Did you ever have any luck in resolving this issue?
Nope. I have a 3/14 build date too, but used the most recent update. Still as broken as the day I got the car.
Only thing I can think of is he may be using an Android with the spotify app?
      12-30-2014, 01:07 PM   #32
turnstile
I've tried rolling back the OS and reinstalling without luck. Maybe it's the iOS version that is the difference. I'm running v7.1.2. Perhaps iOS v8.x is what the other member is running that is working.
      12-30-2014, 01:14 PM   #33
qballis
Nope again. I'm using iOS 8.1.2.
      12-31-2014, 03:30 AM   #34
kd0t
Anybody else's sometimes glitches?
      12-31-2014, 09:22 AM   #35
AWcoupe
AWcoupe's Avatar
166
Drives: 2023 BMW 240i xDrive
2023 BMW M240  [0.00]
2015 BMW 235xi  [0.00]
My car is an August '14 build and this is what my iDrive is showing as the installed software version. If the above is the latest update would that mean that my 002-045 is outdated? You'd think that the higher number would be the latest, no? What am I missing? Cuz then you'd think that the latest update would put the "45" on the car.
2023 BMW M240i
2015 BMW 235xi
Alpine White, Coral Red Dakota.Traded
2009 BMW 328xi Alpine White-Traded
      12-31-2014, 12:34 PM   #36
turnstile
My car is a 3/14 build and with the update it's also showing TH-002.039.062/MN-002.039.060. I do have the premium and tech packages so perhaps thats where these different 'build' versions come from.
If you read the PDF of the update it shows different versions of the update, one that fixes the bluetooth stream meta-data problem and one that doesn't which is the upgrade the new OS bin updates my car to. Makes no sense to me. See below.
Software update (MN-2.255.60, TN-2.255.62)
Contents
▷ Multimedia: remedies a problem where a superfluous note on app installation is dis‐ played.
Remedies a problem where the old meta‐ data are displayed after changing the track.
Resolves a problem where long tracks were not saved correctly.
▷ Telephone: improved stability during synchronisation of messages.
Individual reminders can be closed.
Improved operation during the synchroni‐ sation of contact data and messages.
Optimised display of journeys made in the service Online Driver's Log.
Improves the display of special characters in the ConnectedDrive portal.
Call lists from LG, Samsung and Blackberry devices are transferred.
Improved display of Chinese names in Chi‐ nese vehicles/national versions.
Improved Reconnect function.
Supported devices
The software update improves the compatibil‐ ity of the following devices:
Multimedia
▷ Apple: iPhone 4, 4S, 5, 5C, 5S (iOS7)
Phone
▷ BlackBerry: 9800, 9900 (OS 7.1)
▷ Samsung: Galaxy S4
▷ Various: Devices with Bluetooth connec‐ tion
Notes
Following installation of the software update, the current software version is displayed in the vehicle:
▷ Media: MN-2.255.60 ▷ Phone: TN-2.255.62
Software update (MN-2.39.60, TN-2.39.62)
Contents
Improved music search function on Apple devices in Japan.
Remedies a problem with music playback on Apple devices via Bluetooth (loss of sound).
Remedies a problem with the music search function for Sony Xperia Z1 (multiple list entries).
▷ Telephone: individual reminders can be closed.
Optimised display of distance in kilometres and miles in the service Online Driver's Log.
Software update information
UPD05062.bin
UPD05062.bin
Improved audio playback via Bluetooth with Apple iPhone.
Improved connection stability via Blue‐ tooth.
Improved system stability when using BlackBerry devices with OS10.
Remedies problems with message display via Bluetooth on Samsung devices.
Supported devices
Multimedia
▷ Apple: iPod touch 4G, touch 5G
▷ Apple: All devices (when used in Japan)
▷ Sony: Xperia Z1
Phone
▷ BlackBerry: Devices with OS10
▷ Motorola: Razr i
▷ Samsung: All devices
tion
Notes
▷ Media: MN-2.39.60
▷ Phone: TN-2.39.62
      12-31-2014, 12:35 PM   #37
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Thanks will do this tonight.
Edit: No joy. Will try reloading with the iPhone adapter removed to see if that was the issue. The download from BMW site indicates this is a good update and I had done the previous update back in May of 2014.
Removing of Snap-In adapter didn't help. New software update will not load on 2/2014 build.
      01-04-2015, 10:57 AM   #38
TurboKoo
Lurker from behind
No_Country
Drives: Porsche Boxster
You need to download it it usb stick and then update.
      01-04-2015, 01:09 PM   #39
Delnari
Delnari's Avatar
Duh! I have done this earlier in the year, so I know how to update the iDrive. Heck, I successfully updated the NAV software and one of the first here to code their cars.
Appears my HU is too old for this update with a build date of 2/2014. Anyone with a build <= 2/2014 get a successful install.
      01-10-2015, 05:23 PM   #40
Oyinko
I have the same issue because my car is from 02/2014. So I can't install the new update but I still have the problem of track update with spotify.
      01-11-2015, 05:25 AM   #41
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Did not work for me. I think I have to wait until I get back stateside and my NAV, SAT and connected drive is enabled.
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
      01-11-2015, 09:45 AM   #42
moltenfire
moltenfire's Avatar
Drives: 2015 M235i EBII Coral Red
2015 M235i  [0.00]
I have a build date of Nov 27, 2014 and the website also shows both updates for me as well.
