01-07-2016, 12:19 AM | #1 |
Rep 28
Drives: 6MT M235i Alpine White
Breaking in new m235i
I just got my brand new BMW M235i on Sunday and the dealer didn't say anything about breaking in my car. Does anybody know the proper way to break in my car? I have to be honest since Sunday I have been having a little fun with the car, it is a manual so i've been pushing it all the way to redline at times. My car only has a 100 miles so far and I got it out the dealer with only 15 miles. I'd really appreciate if someone told me the proper way to break in my engine. Thank you
01-07-2016, 12:38 AM | #2 |
Rep 1,753
From the manual found here: http://www.bmwusa.com/Standard/Conte...modelcode=162C
"Breaking-in period General information Moving parts need time to adjust to one another (break-in time). The following instructions will help accomplish a long vehicle life and good efficiency. During break-in, do not use the Launch Control, refer to page 74. Engine, transmission, and axle drive Up to 1,200 miles/2,000 km Do not exceed the maximum engine and road speed: ▷ For gasoline engine 4,500 rpm and 100 mph/160 km/h. Avoid full load or kickdown under all circumstances. From 1,200 miles/2,000 km The engine and vehicle speed can gradually be increased. Tires Tire traction is not optimal due to manufacturing circumstances when tires are brand-new; they achieve their full traction potential after a break-in time. Drive conservatively for the first 200 miles/300 km. Brake system Brakes require an initial break-in period of approx. 300 miles/500 km to achieve optimal performance between brake discs and brake pads. Drive moderately during this break-in period. Clutch The function of the clutch reaches its optimal level only after a distance driven of approx. 300 miles/500 km. During this break-in period, engage the clutch gently. Following part replacement The same break-in procedures should be observed if any of the components above-mentioned have to be renewed in the course of the vehicle's operating life."
01-07-2016, 07:58 AM | #4 |
Rep 1,753
01-07-2016, 09:26 AM | #5 |
Rep 243
01-07-2016, 09:41 AM | #6 |
Rep 1,753
He has to be sure that the engine is cold too, so wait at least 2 hours (not minutes) in between rebel revs.
01-07-2016, 02:59 PM | #7 |
Rep 190,807
Manual says keep it under 4500 rpm for the first 1200 miles ... most people drive like they stole since day 1
Doubt engine will suffer any damages either way
01-07-2016, 07:03 PM | #8 |
Rep 28
Thank you so much I appreciate it
01-07-2016, 07:07 PM | #9 |
Rep 1,753
On a serious note, when I break in a car I mostly follow the suggested method.....mostly. It's too tempting not to get on it once or twice.
01-09-2016, 08:51 AM | #10 | |
Rep 241
Came across this interesting article from PCA (Porsche Club of America).
Sounds like engines are not truly broken in from the factory. I plan on following BMWs break in advice for their M cars. Keep it under 4k RPM for the first 1,000 miles then slowly bring it up. ^^^ From an earlier post I made. I'd follow the break in procedure, you need to allow things to wear in properly. |
01-09-2016, 10:05 AM | #11 |
Rep 1,753
Ah, that makes a lot of sense. Just one question though. What does "bring it up slowly" mean? 1,000 rpm per 100 miles over break-in? That would seem reasonable.
I have a 4 hour drive home after PCD. I hope I'll be able to cruise at speed as well as be able to vary my speed, and therefore rpm, enough. |
01-09-2016, 10:35 AM | #12 | |
Rep 241
I think I did 3500 tops for the first 600 miles, 4000 tops until 1000 then 4500 until 1200. After 1200 miles I changed all the fluids (see one of my other threads for that info, I make a decent case as to why you should do this.) I have had no issues with oil burning whatsoever. |
01-09-2016, 12:18 PM | #13 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
Break In Period
01-09-2016, 03:54 PM | #14 |
Rep 45
Word of the week: Wärmeausdehnungs
When parts are toleranced for a 250k mile + lifespan, they are naturally tight when brand new. Revving the piss out of tight bearings gets them very hot, very quick... |
01-10-2016, 02:25 AM | #15 |
Rep 28
I'm breaking in my engine also, I cannot wait until I can drive the car the way its supposed to be driven
01-17-2016, 06:47 PM | #16 | |
Rep 9
01-17-2016, 07:13 PM | #17 |
Rep 9
Proper break in.
I had one more thought on this topic. I purchased my 2013 328i, M Sport, 6 speed manual from a very enthusiastic, knowledgable, sales associate. I special ordered the car with the options I wanted. My sales advisor went on and on about how I made a great choice by going with the manual transmission. When I took delivery of the car, it had 18 miles on it! I always felt like the car had a very weak first gear. It honestly was the one huge disappointment that I had with the car. So...... I think my sales guy raped the car when it was brand new and wore something in the drivetrain. That being said, I'd recommend taking as long as you can stand it to break you car in. My M235i got absolutely terrible mileage for the first three tank fulls of gas. That leads me to believe that the BMW engines are very tight when new. I'm talking that I got 12-14mpg keeping it under 4500rpm's and staying out of sport mode. My mileage has increased dramatically after 500 miles.
01-19-2016, 12:04 PM | #18 | |
Rep 241
01-19-2016, 01:44 PM | #19 | |
Rep 536
This is what i would do for the first 1000km Take into the hills load up the engine and fluctuate the RPM - never hold or just sit on the freeway ! Drive hills as many a you can. Avoid going WOT but certainly don't baby it or you will end up with oil usage issues and a lazy car! Then take it back to the dealer and have them replace the oil and filter , After that you can start getting stuck into it and I mean driving the car very hard ! Good luck
01-20-2016, 02:55 AM | #20 | |
Rep 26
Opps I drove it hard from the beginning. Will my engine damage in near future? |
01-20-2016, 08:11 AM | #21 | |
Rep 45
I think dropping the oil is a must after break in. I had a magnetic sump plug on an Civic type R, after swapping in new cams and valve springs the next oil change presented a large clump of iron particles on the magnet. Imagine the material from a whole new engine! |
01-20-2016, 11:40 AM | #22 |
3441
Rep 79,211
I think I waited 17 miles before I put the loud pedal down. Break in is highly over-rated.
Majority of the wear and break in happens at the factory. Biggest problem I see is when people buy cars from different states then drive 400 miles or more on a long trip home, that's the worst. Heat cycling the engine and varying RPM is how to do a proper break in. That includes time letting the engine cool. |
Tags |
engine |
