09-11-2018, 05:51 PM | #23 |
Rep 503
I just assumed that when the coolant was low, the car would send a message via Connected Drive and a service agent would be dispatched to your location immediately to refill. Is this not the case?
09-11-2018, 07:06 PM | #24 |
Rep 5,262
09-11-2018, 07:27 PM | #25 |
Rep 611
Exactly. On my '18 M240i, the low-coolant light continues to come on from time to time, for no more than a second or two. Sometimes more frequently than others, for no apparent reason. The odd warning is not due to low coolant; both reservoirs have been checked and rechecked. The light comes on randomly, unrelated to any circumstance in particular, and therefore it can't be replicated for a service advisor. I keep hoping that someone with this problem will stumble on the problem/fix... it's the only issue I've had with the car, but it still annoys me.
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
09-11-2018, 07:40 PM | #26 | |
Rep 400
stevenvillatoro734.50 |
09-11-2018, 10:24 PM | #27 |
3612
Rep 3,579
The sensor is capacitive (two vertical probes in the tank bottom). It only seems to be available as part of the expansion tank. Likely false level warnings are caused by either corrosion or deposits on the probes. Topping up with the wrong coolant, not using distilled water for coolant dilution or the wrong coolant concentration may be contributing factors to sensor contamination or corrosion.
dradernh4347.50 |
09-12-2018, 07:27 AM | #28 |
Rep 1,219
Drives: 2015 M235ix
I have 34000 miles on my car. At about 20000 miles, my 20-something daughter was driving the car locally and the warning light went on. She responsibly stopped at the nearest corner gas station, they sold her some generic coolant and poured enough into the tank to fill it. Nothing since.
This leads me to agree with others that the persistent signal is likely due to a faulty, maybe corroded, sensor. The dealer or a competent independent can check that without having the warning active. |
09-12-2018, 09:52 AM | #29 | |
3612
Rep 3,579
09-12-2018, 10:29 AM | #30 | |
Arsevader
36
Rep 128
09-12-2018, 10:36 AM | #31 | |
Rep 3,493
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
09-12-2018, 11:30 AM | #32 |
3612
Rep 3,579
When helping friends or family buy used BMWs I always have a couple of basic rules, the coolant one is - if it is blue the car is worth looking at, if it is green, orange or brown 'run away', any other colour ask for documentation to prove what was used is BMW compatible. Too many issues with BMWs and other European cars in North America over the years with cooling system failures due to the wrong coolant being used.
TajoMan174.00 |
09-12-2018, 06:30 PM | #34 | |
Arsevader
36
Rep 128
12-17-2018, 03:15 PM | #35 |
Rep 13
So I first started researching this issue about 2 months ago when I took my 2018 M240i in for its first scheduled service at 9k miles. I started getting the low coolant warning about a week before my appointment. Like most others I read about, I checked both reservoirs and the main one was indeed under the "low" mark. As instructed by the stealership's service department, I topped her off with distilled water until they could get a look at it in a week's time. I did that and did not have the coolant warning come back. I also had no evidence whatsoever of any leaking anywhere I parked. I took it in for the appointment and the tech said the same as most have posted, that it was most likely slight evaporation and wasn't completely topped off from the dealer and there were no leaks of any kind anywhere. I kept a keen eye on it for the next month and saw no issues so I thought nothing more of it.
Fast forward to this past weekend. I took a short trip to a friend's Christmas party who lives about 2 hours away (125 miles one way). I get back into town and right as I'm on my last 5 miles of the trip, the coolant warning comes on again. I get home, park and within minutes I could see a pool forming under the front left (if you're looking at the headlights). I thought it may be water condensation from running the A/C, but nope, it definitely had a blue tint. After the car cooled down enough to check late that night I confirmed that the main reservoir was below the "low" mark again considerably. I called the stealership's service department this morning and scheduled to take it in. It's currently sitting there waiting for assessment. For reference, I don't drive the car hard a lot. Mostly the only time I really get on it is when I'm merging onto the interstate going to and from work each day. I'd say it's about a 50/50 mix of highway/in-town driving. I just passed 11000 total miles. No mods of any kind, so it's straight factory. I'll update this when I get word back from the service department. |
12-20-2018, 01:57 PM | #36 |
Rep 13
Confirmed Coolant Leak - Update
So I got a call from the stealership Tuesday morning. They found there was a puncture in my radiator which looked like it had been caused by a rock or some other debris from the road kicking up and hitting it. So either I am the unluckiest person in the world or there is a serious design flaw that would allow for something like this to happen. Long story short, it's not covered by warranty and oddly enough it appears it was not related to my initial low coolant issue a couple months ago. Either way, I'll still be keeping an eye on the coolant levels moving forward.
12-20-2018, 02:09 PM | #37 | |
Rep 3,493
The rock guard in this realoem.com image is BMW's solution: These were my solutions:
12-20-2018, 05:28 PM | #39 |
Rep 3,493
I didn't do the work. I'm pretty certain that the bumper cover was removed so that the screens could be installed.
12-23-2018, 04:08 PM | #40 |
3612
Rep 3,579
I just finished using black aluminium mesh to cover all 5 of the grille openings to protect against damge. I obtained the material from here: https://www.amazon.ca/Lanlan-6x12mm-.../dp/B07B93TQSW
overcoil3073.50 |
12-23-2018, 08:14 PM | #41 |
Rep 184
Is the low coolant issue only on the 240i?
I'm curious why this is not an issue w/the 230i? Similar cooling system, no? Has anyone w/a 230i experienced this coolant issue? I'm looking to buy a new DD (240i, or now 230i?) and I don't want to deal with this type of annoyance/irritant. TYIA/cheers, B
Previous BMWs: '87 325is; '06 X3; '09 X3; '11 328i x-Drive; '12 R1200 RT; '13 128i; '13 X3 35i MSport
Other/Current: '19 Porsche 991.2 TT; '21 Jeep Wrangler JL80A; ‘23 Lambo Huracan EVO RWD |
12-24-2018, 03:17 PM | #42 | |
Rep 1,227
BenDiem76.00 |
12-24-2018, 07:18 PM | #43 |
Rep 51
2017 240i. First coolant warning was at around 8k and then again at around 19k miles. Both times coolant needed to be topped off and it took a little under 1 quart both times.
12-25-2018, 11:30 AM | #44 |
Rep 32
2018 240i 3500 miles.
Reading these posts I visually checked both reservoirs although no warning light. Coolant level was definitely below the 'low' indicator. 50/50 BMW coolant added which required less than a pint to bring both to full. Wondered why the idiot light was not activated... |
