2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Er Downpipe Install Diy (sorta) And Pics
      08-21-2018, 05:17 PM   #45
GS235XI
GS235XI's Avatar
Drives: GS BMW M235XI
Originally Posted by Jeff@TopGearSolutions View Post
Originally Posted by GS235XI View Post
Are there any issues with just running with the CEL light. Will the car try to compensate for the oxygen misreads?
Assuming the code is just for being catless, no issues. That code just means your catalytic converter (if it were installed) is not in spec.
Thank you!
      08-24-2018, 12:31 AM   #46
TwistedX
Really Twisted
Drives: 2015 M235i F23 8AT
Honestly this can be done in less than an hour, not counting the million belly pan bolts, super easy to do
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold
      08-25-2018, 12:18 PM   #47
GS235XI
GS235XI's Avatar
How do I reach the top v clamp. Can't even see the bolt. Is it different for the x drive?
Will the v clamp rotate if I take off all the bottom stuff?
      08-25-2018, 08:18 PM   #48
TwistedX
Really Twisted
You can just see it from the bottom but I was about to access the bolt very easily from the side/wheel well area
      08-25-2018, 08:21 PM   #49
GS235XI
GS235XI's Avatar
Thank you. Hoping to try again tomorrow. I will look through the wheel well for access.
It's a lot more cramped up there and longer than i thought it would be. Now just hoping if I do get it off, I can get it back on.
      08-25-2018, 08:34 PM   #50
TwistedX
Really Twisted
I bought my car CPO so maybe something is different or it had a DP before but the whole install from stock to aftermarket took less than an hour on jackstands with nothing more than a 3/8 ratchet, a deep 13 and 16mm socket, a 6 and 10in extension and a ujoint socket thingy but didn't really use the ujoint thingy
      08-25-2018, 09:38 PM   #51
GS235XI
GS235XI's Avatar
Help again.. got everything done. Top V clamp is loose, but not all the way off. How to I finish this SOB
Update....
Removed the whole bolt from the top V clamp. This loosened it enough to get the downpipe off it. Then 15 min of wiggling it past the mid pipe, it's out
Likely 3 hours in so far with 1 of the 3 being productive. Now just for the install.
      08-26-2018, 10:33 PM   #52
GS235XI
GS235XI's Avatar
Me again. Got it almost done. Top V clamp is my last issue. I tried putting the bolt in first but then the opening wasn't big enough. Now I have it all fit, but I can't get the bolt to the other end of the v clamp to start tightening it...
Thoughts....?
Update for those that come after me. I bought a new 8MM bolt for the top v clamp that is much longer than the original bolt. This allowed me to connect the bolt while still having the clamp at its maximum open width. Then lined up he v clamp and started tightening.
Hoping to finish tonight
      03-06-2019, 08:33 PM   #53
miamipanther
Drives: 2012 X5
We are going to replace our DP too? How did you get the V clamp eventually?
Thanks
      03-07-2019, 05:43 PM   #54
GS235XI
GS235XI's Avatar
Thanks
I took everything all the way off and got a new longer bolt that allowed me to position the v clamp around the dp without having to clamp it with my hand. I then tightened it front the top making sure it was positioned to face upwards.
2 people would help. I can attest it is possible with one. Leave the back part of the exhaust loose while getting the DP in position.
Best of luck. Feel free to reach back out with questions.
      03-07-2019, 05:49 PM   #55
miamipanther
Drives: 2012 X5
Thanks for your prompt reply. Did you access the v-clamp through the wheel wall? It seems too far from bottom and too narrow to get hand in from the top of the engine bay.
      03-07-2019, 05:51 PM   #56
GS235XI
GS235XI's Avatar
I dropped crazy long extension from the top and reached through the wheel well to position it on top of the bolt.
      03-07-2019, 05:59 PM   #57
miamipanther
Drives: 2012 X5
That's creative As so you did remove wheel well liner to get access
      03-07-2019, 08:36 PM   #58
GS235XI
GS235XI's Avatar
I did not remove the liner
      03-07-2019, 11:45 PM   #59
miamipanther
Drives: 2012 X5
That would be awesome, I will try this way.
      06-04-2020, 03:24 PM   #60
Skrrtt335
Drives: 2015 335
nice write up
