2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Anyone have N55 MHD stage 1 dyno numbers?
      03-15-2019, 02:06 PM   #1
lordinfamous666
Drives: 15' M235i F23 Estoril Blue
Hey Guys,
a week ago I flashed my F23 with MHD stage 1 (93 oct) and i def feel a big improvement although I have not once given it full throttle from a dig yet because I am on stock charge pipe as I am afraid to blow it, but I have a VSRF charge pipe in my trunk that I ordered which will be installed tomorrow morning.
I have searched google all over for someone posting MHD stage 1 dyno numbers but have not found any. Can anyone with some experience give me some information?
Thank you and have a great weekend!
      03-16-2019, 12:19 AM   #2
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
https://f30.bimmerpost.com/forums/sh....php?t=1547066
Get BM3
      03-16-2019, 11:31 AM   #3
lordinfamous666
Thank you for the reply, that was another N54 MHD stage 1 dyno, not an N55. I can find N54 dyno results all day, its the N55 I am looking for. It looks like no one has anything. I am not trying to squeeze every last bit of power from my cars hardware, I prefer a middle ground of power and reliability. If I am truely getting 360whp I will be more than happy. I JUST got my chargepipe installed and I am at my mosque for prayer and when I am done I will give it some WOT.
      03-16-2019, 11:45 AM   #4
Taskmaster
Japan
2465
No, it was a EWG N55, the op literally says it.
The OTS makes for MHD all look like shit to me. Lower Boost, lower timing- they may be dialed for PWG turbo cars, but they are lacking for EWG. Just use the vendor list and grab a custom tune.
      03-16-2019, 12:10 PM   #5
lordinfamous666
Ok sorry, I misread the thread. How do I get a custom tune file to flash through MHD? Can anyone point me to one/some?
Thank you!
      03-16-2019, 12:11 PM   #6
lordinfamous666
Can you tell me where I can find the vendor list? I am on the MHD app now and do not see it. Thank you.
      03-16-2019, 07:27 PM   #7
Taskmaster
Japan
2465
mhdtuning.com/partners/
      03-18-2019, 03:12 PM   #8
lordinfamous666
Thank your for all your help. Last question, are the MHD claimed numbers (up to 360hp) wheel numbers or crank numbers?
I got my charge pipe installed last weekend btw and am loving it... huge difference with tune vs stock. I had burble effect on the "softer" setting but turned it off because I heard people saying online that it is bad for the turbo seals & cat.
      03-18-2019, 03:22 PM   #9
Taskmaster
Japan
2465
I believe they are likely crack Hp numbers. Those maps are too soft to make that type of power. I wouldn’t run the burble with stock cars in place either.
      03-22-2019, 07:28 AM   #10
lordinfamous666
I really appreciate your help, brother.
      03-23-2019, 12:15 PM   #11
Taskmaster
Japan
2465
No problem, good luck.-
      03-28-2019, 09:39 PM   #12
serrated
Drives: M2
I assume all the flash tunes are similar in results.
I went hex tune but I did 301/310 stock, 345/380 stage 1, and 360/450 stage 2
Edit: to the wheels on dynojet. https://www.youtube.com/playlist?lis...YHArXjNkRByXCU
dr.roro195.50
PN3UMA27.00
      03-29-2019, 04:30 PM   #13
dr.roro
Drives: 2019 G01 X3
Awesome videos man. I'm basically planning to do the same this year with my 435i. What gear did they use for the dyno runs?
      03-31-2019, 09:04 PM   #14
serrated
Drives: M2
what do you mean by 'gear' in this context?
      04-01-2019, 05:52 AM   #15
dr.roro
Drives: 2019 G01 X3
4th? 5th? 6th?
      04-05-2019, 04:38 PM   #16
serrated
Drives: M2
4th? 5th? 6th?
6th is 1:1 IIRC, but 5th gave me better numbers for whatever reason lol
      04-05-2019, 06:41 PM   #17
jb-slow
Drives: m235i
6th should be overdrive, and mess up everything, 4th has been 1:1 in most of my other cars
      04-05-2019, 06:42 PM   #18
dr.roro
Drives: 2019 G01 X3
6th is definitely 1:1 on the ZF 8AT, but I have seen most people do 5th or even 4th. I'll go with 5th if/when I do dyno later this year.
      04-06-2019, 11:06 AM   #19
jb-slow
Drives: m235i
Oh, autos..... I have a manual, my bad
