HP Autosport || Ultimate Clutch Pedal for your F2x 2-series |
11-25-2021, 08:34 PM | #141 |
Supreme Allied Commander
3847
Rep 54,378
Drives: F80 M3
UPC in stock! |
12-24-2021, 08:34 PM | #146 |
3847
Rep 54,378
Drives: F80 M3
…a must for all modern “Sporty-Driven” (manual) BMWs.
The “Ultimate Clutch Pedal” is a short-throw clutch pedal made of billet aluminum and 6061 aluminum tube. It fits all LHD manual BMW 3-series cars 2007 and up. Includes (E90/92 and up including F-models) along with all manual 1-series cars and X1 chassis. “Slop” is completely eliminated by the use of precision maintenance-free bronze bushings and stiff billet CNC-design pivot block. Feel is greatly increased due to the elimination of all plastic and flex in the pedal system. The slightly shorter throw makes for quicker shifting and a more positive feel. Lower pedal resting location (15mm lower) lines up pedal better when braking and requires less “leg-lift” from the dead-pedal. The over-center spring is user adjustable with 3 settings (Stock - Sport - Race). Includes adjustable clutch stop that allows user to fine-tune the pedal travel distance and carpet clearance. Satin tumbled surface is then finished in anodized black. Pedal pad shape is compatible with OEM rubber or any after-market pedal pad kit. Easy end-user installation requires no alterations to the car and no special tools. Race-proven performance – positive feedback… Tested by amateur and professional racers. |
12-30-2021, 03:39 PM | #147 |
3847
Rep 54,378
Drives: F80 M3
in stock
02-17-2022, 03:01 PM | #153 |
3847
Rep 54,378
Drives: F80 M3
…a must for all modern “Sporty-Driven” (manual) BMWs. The “Ultimate Clutch Pedal” is a short-throw clutch pedal made of billet aluminum and 6061 aluminum tube. It fits all LHD manual BMW 3-series cars 2007 and up. Includes (E90/92 and up including F-models) along with all manual 1-series cars and X1 chassis. “Slop” is completely eliminated by the use of precision maintenance-free bronze bushings and stiff billet CNC-design pivot block. Feel is greatly increased due to the elimination of all plastic and flex in the pedal system. The slightly shorter throw makes for quicker shifting and a more positive feel. Lower pedal resting location (15mm lower) lines up pedal better when braking and requires less “leg-lift” from the dead-pedal. The over-center spring is user adjustable with 3 settings (Stock - Sport - Race). Includes adjustable clutch stop that allows user to fine-tune the pedal travel distance and carpet clearance. Satin tumbled surface is then finished in anodized black. Pedal pad shape is compatible with OEM rubber or any after-market pedal pad kit. Easy end-user installation requires no alterations to the car and no special tools. Race-proven performance – positive feedback… Tested by amateur and professional racers. |
02-23-2022, 10:37 AM | #154 |
3847
Rep 54,378
Drives: F80 M3
