03-18-2016, 07:20 AM | #1 |
Rep 41
Just got JB4 and ER chargepipe installed. Some questions
Recently collected my 228i, and to be honest, a little underwhelmed at the performance. Love the way the car handles though. Running an automatic transmission.
So i decided to look into possible tunes, talked to a few workshops, and ended up with JB4 and the ER chargepipe. Noticed alot of users here are contemplating on a tune but like me, are not sure if they want to take the leap, so i'll be chronicling my experience for others. First i have a few questions i hope some veterans here like mike can assist with. I'm a little confused about JB4 versus BMS stage 1 and the whole thing with stages in general. my questions: I'm currently running JB4 on map 1. Most importantly, is this safe to run JB4 MAP 1 without any other modifications ? (Everything else is stock) Is map 1 considered a stage 1 tune? What then is considered stage 2 with JB4? Or even better, would be great to understand what defines each stage: JB STAGE 1 JB4 Stage 1 JB4 Stage 2 JB4 Stage 3 Current: ER CHARGEPIPE + JB4 NEXT: WAGNER COMPETITION EVO1 INTERCOOLER NEXT : IGEN INTAKE I did a dyno at stock and am planning to do another dyno run with each drop in added so i can see the benefits each time i add an item as well as share my impressions. STOCK (no mods nothing) JB4 MAP 1 + ER CHARGE PIPE [DYNO COMMING SOON] Impressions: Torque comes in faster and longer. The torque increase is also extremely pronounced, and the throttle response is far improved. I'll be doing a dyno right before the next mod. Last edited by BimmerLOVER1234; 04-16-2016 at 12:21 PM.. |
03-18-2016, 07:45 AM | #2 |
Rep 887
Drives: Enzo F23 228i
Not sure what you expected from map 1, and the charge pipe would do nothing for performance, but you should have a little more "punch" on the low end.
03-18-2016, 07:51 AM | #3 |
Rep 41
i didn't expect anything actually (or rather just didn't know what to expect? i just wanted it to be better than stock). but was pleased with the result. the dyno i linked is totally stock before map 1. i will do another dyno for map 1 with the jb4.
The main questions i have is to understand the difference between the varous stages, and which stage does map 1 represent? (Also is it safe to run map 1 with almost everything else stock.) i see people saying their JB4 is stage 2, but what exactly is JB4 stage 1 or 2? is it the maps? Last edited by BimmerLOVER1234; 03-18-2016 at 07:57 AM.. |
03-18-2016, 03:09 PM | #4 | |
Rep 190,807
Stage 2 connects to the Canbus, which gives it access to RPM, Fuel, AFR,etc... Yes you can run map 1 with a stock car .. Jb4 offers the same map as JB stage 1 on map 1 Here is a full list of maps Map 0: JB4 disabled. Map 1: PWG models absolute target 21psi peak, EWG models additive 4psi peak over stock. Map 2: PWG models absolute target 22psi peak, EWG models additive 6psi peak over stock. Map 3: Progressive Methanol Injection. Requires BMS methanol kit or BMS FSB for meth pump control. Map 4: Stock performance, JB4 on Map 5: Absolute targeting map with a peak boost 17psi. Suitable for 320 & 520 applications. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas absolute target map. Peak boost 23psi. This is a fairly aggressive map and increases engine damage risk. Use with caution.
03-18-2016, 09:02 PM | #5 |
Rep 167
Both the injen intake and charge pipe don't do much for preformance, but more for better protection in case you plan to run higher boost(charge pipe) or maybe a bigger turbo in the future(only then you'll benefit/add power from the injen intake)
If you already have the jb4 in and don't feel as if map 1 is adding that extra push, the downpipe/exhaust/93 octane combination will give you the full benefits of map 2 (which you should only use with those mods installed if you weren't aware) That will definitely increase your power, not " just feeling like it's faster". |
03-30-2016, 02:40 PM | #8 |
Rep 356
04-01-2016, 06:49 AM | #9 |
Rep 41
Just got the ER downpipe installed:
First Impressions are that the car is less refined, with more rumble. The workshop told me that it will get better after 2 days. anyone had any experience with this? Would be great if other ER downpipe users could share their experience. Also, i noticed low end torque seems to actually be less, while high end power and mid range power seems more potent. will do more testing. The dyno was packed with people waiting so i've made an appointment next week to run :JB4 OFF with downpipe :JB4 ON with downpipe |
04-01-2016, 11:11 AM | #10 | |
Rep 190,807
04-06-2016, 07:44 AM | #11 |
Rep 167
I have had ER Downpipes and Jb4, intake etc.. in for 5k miles or so, and the power increase imo is noticeable in low, mid, and high end, but definitely in mid/high end more than anything. The sound is such an impressive growl even for a 4 cyl, and will be slightly louder on start up/warm up as you break it in.
04-06-2016, 01:11 PM | #12 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
What was the cause of the dip from 3400-3600rpms? That's strange to me...it recovers power-wise..but still stands out. So what were the stock numbers? 240rwhp??
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
04-07-2016, 06:41 AM | #13 |
Rep 41
That image is the stock numbers. i haven't done the run with the other items yet.
Been trying to settle in with the ER DP, but not too happy so far as the change in the amount of vibrations felt in the car is pretty drastic. May even consider removing it. Basically, the seat and the floor vibrates everytime i go past the 2.5k rpm mark, it just feels really rough, and the car vibrates at idle after some driving. Takes the fun out of this pretty much. |
04-20-2016, 10:56 AM | #14 | |
Rep 1,541
Sounds like you might have an install issue. Maybe a bad exhaust leak or it's vibrating against something under the car. |
04-24-2016, 01:44 PM | #15 |
Rep 41
Some updates. found a spot where the fitment was touching, vibration is gone!
Had the wager evo competition intercooler installed as well. Changed rims to 7 KG advan Rs rims Power delivery is smooth, consistent and significantly more potent. A dyno is coming now that i'm satisfied with the result! Next up! , Big brake kit and KW DDC coilovers! |
