12-01-2022, 09:15 PM | #1 |
Rep 239
Drives: '17 M240i 6MT
Cosmo Racing Short Shifter
While looking at short shift kit options for the 2 series, I came across something peculiar. Cosmo Racing (which I've never heard of until today) apparently makes a short shifter for the F22. I can't find any info online about this kit, apart from one or two install guide videos on a 220i. It's also remarkably cheap at $120, compared to the $400+ for Turner or other reputable brands. Does anyone have experience with this part? I'm interested purely due to how cheap it is; I might just buy it and be the guinea pig if no one on the forum has tried it before.
https://cosmoracing.com/en/bmw-f22-f...rt-shifter-bmw |
12-02-2022, 09:39 AM | #2 |
Rep 913
Never heard of them either - but remember cheap and quality, are rarely mutually inclusive.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
12-02-2022, 03:00 PM | #3 |
Rep 1,796
It needs more than a lever to shorten the throw... that looks to be just a shorter rod. A short shifter will modify the carrier so the "ball" sits higher.
That might be what that blue piece does, sit inside the OEM socket? I'm not 100% sure. |
12-02-2022, 03:10 PM | #4 | |
Rep 239
https://youtu.be/momwVpFwGzA
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
