2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235i transfer case failure.
      06-10-2019, 06:42 PM   #1
Badcatm235
Drives: 2015 M235i Xdrive
Well it happened to me. Stock 50k miles 8spd auto. First thought it was a missfire, that was ruled out and deemed to be the transfer case. Symptoms were a jerking sensation under wot and load. My question is what commonly fails on the BMW transfer cases? Is it the clutch pack or just the actuator? Any help would be appreciated as I'm just a curious bugger.
      06-12-2019, 04:58 PM   #2
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
We have a couple threads with good info in the F3x diesel section (as our cars fail the most).
Transfer case failure database
Transfer case flange repair and prevention
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      06-12-2019, 06:38 PM   #3
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
you running staggered wheel setup? If so, that's probably what caused it. I learned the same lesson on my old is350.
      06-14-2019, 11:30 AM   #4
FaRKle!
The data we collected on F3x transfer case failures doesn't support this claim (if using tire ODs within xDrive spec).
      06-14-2019, 08:40 PM   #5
amw896
amw896's Avatar
that's valid on every awd car to a point. My IS350 allowed a max of 3.5% rolling diameter difference between front to back. I was running 6.5% before my transfer case grenaded. My own fault for not researching before hand. I dont know what the allowable is on BMWs.
      06-15-2019, 10:16 AM   #6
Badcatm235
Square setup. Going to put it up this weekend and see if it's the actuator or something else. Doing a fluid swap either way and resetting adaptations. Say a prayer for me lol....
      08-29-2019, 09:38 AM   #7
MechEngineer
Drives: M235i xdrive
Did this fix it for you? I was having the exact same issues, I did a fluid swap and it went away. So far its been fine but it has only been 5 days....
