05-30-2019, 10:47 AM | #1 |
Rep 101
M235i overheating at idle
So everyday I drive about 12 miles for my daily commute and the past 2 days when I get to my destination about 3-5 minutes of idling I get engine temp to high to drive cautiously. If I leave it in for about another 60 seconds I get the red engine over heat shut off. Only happened when I was stationary any thoughts?
I drive a 2015 m235i manual with vrsf charge pipes and muffler bypass |
05-30-2019, 11:55 AM | #3 |
Rep 5,369
Water pump or fan is dead or dying. You need to get this fixed ASAP and probably shouldn't be driving. You don't want to warp that $6K cylinder head.
slow_f2217.00 |
05-30-2019, 12:34 PM | #4 |
Rep 101
05-30-2019, 09:41 PM | #6 | |
Rep 101
however I have a appointment with BMW set to get it looked at when I originally only needed to go in to get my oil changed. sadly my warranty ran out in january. i only have 43k miles on my car too. |
05-31-2019, 07:56 AM | #7 | |
Rep 772
Drives: 2015 435i grand coupe xdrive
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
slow_f2217.00 |
05-31-2019, 08:43 AM | #9 |
Rep 101
okay, but the AC works only when moving if i'm stopped or almost stopped it finishes the last little bit of cold air and then it blows room temp air out. and still have not heard the fans kick on higher than usual.
06-02-2019, 08:23 AM | #10 |
DisplacementReplacement
409
Rep 1,100
[QUOTE=jb-slow;24851921]My fans were screaming when my pump died, surprisingly it never over heated, just went in and out of limp mode
how many miles when your pump failed? my N54 pump failed at about 75k and I have 44k on my 235.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
06-04-2019, 04:11 PM | #12 |
Rep 101
mikeyymonster526.00 |
06-04-2019, 08:11 PM | #13 |
Rep 1,117
Drives: 2015 BMW M235i
sounds like a failing water pump...bring it in for sure.
06-12-2019, 10:03 PM | #14 | |
Rep 221
You can check your fan by turning your AC on. When the AC kicks in the fan should turn on (open hood and see if it's turning). Otherwise it is likely your water pump.
ER DP, MPE, ER CP, IC, JB4, Dinan springs
11.624@119.75mph |
06-14-2019, 08:44 AM | #15 | |
Rep 133
stop driving it for 1. 2 take it in somewhere. 3.. stop driving it. |
06-21-2019, 04:24 PM | #16 |
Rep 101
Car has already gone into bmw, they quoted me $12,000 to fix the fans and they suggested a new trans. Took it home and looked at it my self and the relay switch was bad. $33 to fix my overheating issues. I ordered a new fan also and tested it in pair with the original and the original fan was in good condition still. Getting my trans looked at 3rd party since I’m out warranty anyways.
06-22-2019, 01:13 PM | #17 | |
Rep 1,117
12k wtf? A new transmission is like 4k on getbmwparts.com. Stealers, what a joke LOL. |
