2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Left turn signal malfunction
      05-19-2019, 10:01 PM   #1
Duker
Duker's Avatar
Drives: 15 M235i X-Drive
Posted this in a different section but not having too much luck with replies ..... so maybe someone here has encountered this at one time or another ....
Hello ladies and gentlemen, new to the forum and loving it. So much info it's overwhelming!!
I'm the Proud owner of a 15 M235i x drive that I'm absolutely in love with. Bought it almost two years ago with 13k on it and just turned 176k!
Recently I've been having an issue with my left turn signal not working . It was Intermittent at first but now is just out. Replaced the bulb with oem and aftermarket to no luck with it coming back on.
Obviously this far outta warranty it's not going to a dealer . I'm a 20 year service manager and head technician of a large Yamaha dealership so there nothing I'm not confident in fixing myself , but this has me baffled . Since it's a single Filament bulb obviously it's not manipulating voltage to change from a turn signal to a running lamp. So I'm thinking it must be a ground issue ?
This is one of a few issues I'm having with the car, but really wanna get this situation remedied first lol
Dtc's thru the hidden menu show instrument cluster errors E12C1C, E12C20, and E12C40
Not to sure these are relevant to my issue but just thought I'd put all info I have out there .
Any ideas?
      05-20-2019, 12:40 PM   #2
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Any ideas?
It's a ground issue, here's the official fix:
https://www.newtis.info/tisv2/a/en/f...ess/1VnZ8zZX2B
https://www.bimmerpost.com/forums/sh...php?p=22903545
https://www.bimmerpost.com/forums/sh...php?p=22912461
      05-21-2019, 08:24 AM   #3
Duker
Duker's Avatar
I'm not having any issues with the rear besides it flashing fast.. , so can this issue cause the front left amber lamp not to work entirely ???
      05-21-2019, 08:47 AM   #4
Poochie
Poochie's Avatar
Drives: 2016 M2
Actually no, I doubt the front is interconnected to one ground wire of the rear light.
I misread your issue but it still sounds like short of some kind and aside from moisture damage, the ground wire is usually the culprit in these circumstances.
Sometimes a jolt of power burns it out the wire; I would start there by inspecting the wiring for kinks or corrosion.
      05-21-2019, 09:51 AM   #5
Duker
Duker's Avatar
I pulled the inner fender well down well enough to access the connector going to the left front light assembly. Didn't notice any corrosion or major kinks in the wires. I suppose checking voltage to the running lamp power wire would be the next logical step, then ground , etc etc
. I dont have a wire diagram for this car either .... smh
      05-21-2019, 05:07 PM   #6
Poochie
Poochie's Avatar
Drives: 2016 M2
This might help:
https://www.newtis.info/tisv2/a/en/f...ght/1VncCoDjSG
https://www.newtis.info/tisv2/a/en/f...ght/1VnZDyIY4K
Those are the wire diagram for the LED headlights same as the Xenon.
      06-20-2019, 05:52 PM   #7
DaveCN
Drives: '14 M235i, '98 M3
Did you get this sorted? I just got the warning mine was out. Left front is no longer flashing - and from exterior visual inspection, I don't see a burned filament.
      06-21-2019, 08:26 AM   #8
PANDA F22
///AMG Killa
PANDA F22's Avatar
Drives: '15 M235i 6MT
Any ideas?
Did I read that correctly?? You put 163k miles in under 2 years?!
2015 BMW M235i 6MT
      06-25-2019, 06:28 PM   #9
Duker
Duker's Avatar
Yes ... I put a few miles on... I really enjoy driving that car lol
I never did get the left front malfunction sorted out .... however 3 days ago the engine decided to seize. So it's at a dealership. 188k when it went kaboom
I wish I had some information I could give you in regards to this signal issue. It sure seems like a mad ground somewhere to me, I never did get the Opportunity to check the wiring to the actual headlight assembly .
