04-03-2019, 12:11 PM | #1 |
Rep 192
Please note that I also have Dinan exhaust and CAI. The car is AWD on 91 octane. Altitude 3500ft.
04-03-2019, 01:06 PM | #3 |
Rep 192
04-03-2019, 01:47 PM | #6 |
Rep 192
04-03-2019, 11:43 PM | #7 |
Rep 190,805
Thank you for sharing
04-04-2019, 08:31 AM | #8 |
Rep 1,289
did you dyno it when you had the v1 too?
04-05-2019, 04:14 AM | #9 |
Rep 306
dyno
what type of dyno where those numbers run on - I have the exact same mods except MPE exhaust - based on factory claimed numbers those seem really high = I will be tracking our M240 this sunday - Last year with just the tune we did a 12.1 at 109 1/4 with good air -- We are hoping for a high 11 this year - will post slip
04-05-2019, 07:32 AM | #10 | |
Rep 237
Factory claimed is way off according to Dinan. They have it measured at 381 hp and 401 for torque. |
04-05-2019, 10:31 AM | #13 | |
Rep 192
04-10-2019, 06:54 PM | #17 |
Rep 558
Yes. It feels more like the Dinan Sport set on Sport+ (+3 PSI), than the v1 stage 1.
06-02-2019, 03:18 PM | #18 |
Rep 638
06-03-2019, 02:15 PM | #19 |
Rep 306
As posted earlier we have the exact same mods - consistently run low 12 and have had 2 runs in the high 11 - trap speed between 113 and 115 - 60 ft between 1.88 and 1.95 - Our biggest problem is at the line - even with launch control the car had turbo lag hence the crappy 60 ft - we are hoping the Dinan Stage 2 addresses this problem - which should get the car mid 11 in good air - one thing for sure it will really heat soak and does not do well in high DA unless really cooled down - I mean Ice and a fan.
06-04-2019, 12:45 AM | #20 | |
Rep 192
06-04-2019, 04:13 AM | #21 |
Rep 306
DA is a combination of Altitude - Humidity and Air Temp - Turbo cars are really affected by all three - and will experience Heat Soak - One solution is a bigger more efficient inter cooler
06-04-2019, 05:44 AM | #22 | |
Rep 192
Edit: Just found out. Dynamic Altitude. |
