2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum TPMS malfunction
      11-15-2020, 05:52 PM   #1
mblaucoupe135
Drives: 2022 M240i
TPMS malfunction
I have a 2019 m240i xdrive and got a tpms malfunction message this weekend. It's not the same one you get when one of your tires is low as it won't measure pressure at all. anyone else have this happen? Could it be the batteries in the sensors have gone dead? I am currently running a set of 19" vmr wheels on the car.
      11-15-2020, 08:39 PM   #2
leftoverture
leftoverture's Avatar
Drives: 2016 BMW 228i
It is possible a sensor has gone bad. Your local tire shop should be able to test for you.
      11-16-2020, 07:06 PM   #3
mblaucoupe135
Drives: 2022 M240i
thanks! I too am thinking that might be the case. so you think a place like discount tire might be able to test that and figure out which one needs replaced?
      11-17-2020, 11:38 AM   #4
leftoverture
Yep. That is exactly where I would go!
      11-17-2020, 12:52 PM   #5
pmcmtnbkr
pmcmtnbkr's Avatar
110
Drives: BMW M235I
If it a 2019 it should still be covered under the bmw warranty
      11-17-2020, 08:45 PM   #6
mblaucoupe135
Drives: 2022 M240i
well I have an aftermarket set of wheels on it so they probably wouldn't be covered.
      11-18-2020, 01:54 PM   #7
Maynard
Drives: 228iX & M2C
Perhaps too obvious and already tried this, but did you run the full reset program? When mine goes off (too low pressure after track days) it won't read any pressures until I rest it, even if they are pumped back up.
      11-18-2020, 07:08 PM   #8
mblaucoupe135
Drives: 2022 M240i
I haven't tried that yet to be honest so I'll give that a shot. thanks for the suggestion
