2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Will 2016 M235i MPE fit 2017 230i (pre-LCI)
      03-29-2019, 12:04 PM   #1
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Drives: 2017 230i M-Sport
2017 BMW 230i  [0.00]
Anyone have some information? Called BMW parts but they just fed me the "part numbers don't match" answer. I also know a new diffuser would be required.
I expect a small diameter difference which isn't a concern. Looking for overall fitment insight.
2017 230i // Estoril Blue II // M-Sport
      04-01-2019, 03:29 AM   #2
Vincitore
Vincitore's Avatar
46
Drives: BMW 2-Series M Sport
It should fit, as it fits 228i, so you'll have m235/m240 look at the end. But if you're looking for better sound from 4cyl engine there are few aftermarket exhausts you should also consider, in my opinion.
Sisyrx242.50
      04-01-2019, 03:30 AM   #3
espione
espione's Avatar
Drives: BMW 230i Msport LCI
On my 230i LCI I have mounted the 240i MPe exhaust plug&play (both diameters 80 mm).
Also the 235i MPe has diameter of 80 mm, you should have your 75 mm and therefore the need for a small adapter.
Sisyrx242.50
      04-01-2019, 09:50 AM   #4
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Thanks for the info, everyone! I picked up the muffler from another forum member this weekend and just gotta wait for the diffuser to come in now.
      04-07-2019, 03:45 AM   #5
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Update for anyone looking for the same information:
The M Performance Exhaust (MPE) from a 2016 235i required some modification in order to mount into my 2017 230i. The elbow coming off the muffler did not line up well with the stock midpipe and required a bridging piece of pipe to be welded between them.
Looks and sounds great!
      04-14-2019, 08:03 PM   #6
2 Lover
Drives: 2017 F22 230i xDrive
Considering same things on my 2017 230i
How difficult was that?
Is it possible to be done with clamp only or should be welded?
Do you have any pictures of that?
      04-14-2019, 09:37 PM   #7
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
It took a bit of effort, about two hours. They had to create a bridge-type piece of 3" pipe to connect from midpipe to muffler since the M235i's muffler has a slightly different bend.
Clamp was not going to work in this scenario, had to weld. Absolutely worth it.
Just ran down and took some pics for you. The bridge pipe was expanded to 3" in order to sleeve over the midpipe and muffler end.
      04-14-2019, 11:49 PM   #8
2 Lover
Thank you for your effort.
I don’t know where you live but I wanna know how much you paid for installation. Just to get rough idea.
I might be going with 240i m performance exhaust because I wanna do it myself.
      04-14-2019, 11:55 PM   #9
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
I paid $100 in SoCal
If you're looking to do it yourself, definitely get the 240i variant. Without the weld, everything else lines up for a simple bolt-up install with the clamp.
      04-15-2019, 08:02 PM   #10
2 Lover
Considering to install mpe same as you.
What kind of clamp did you use?
If you have a link, please let me know.
Thanks
