2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Limited Slip Differential -- Coding needed?
      05-14-2019, 08:55 PM   #1
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Curious as to if any coding is required after installing a limited slip differential?
If so what is it?
      05-14-2019, 09:44 PM   #2
Rich.Wolfson
Thaumaturge
181
Drives: 2014 M235i
If so what is it?
Nope, No coding necessary assuming you keep the same rear ratio.
///Rich
      05-15-2019, 07:48 AM   #3
neonnblack
Drives: 335i 6MT/e46 330xi
///Rich
Is there specific coding to be done if you do change ratios? The car has a manual trans.
      05-15-2019, 09:03 PM   #4
Rich.Wolfson
Thaumaturge
181
Drives: 2014 M235i
No problem with the MT6. But the ZF8 with bring up a warning when you get to 8th saying there is an issue if the ration is not what it expects. It can be coded but not simply.
///Rich
      05-16-2019, 09:05 PM   #5
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
I asked because I was reading a thread in the F30 3 series forum where it was stated the wheels sensors need recalibrating after differential install.
I had not heard that anywhere before. I know I didn't code anything on my M240 after I had a Quaife installed.
///Rich
