02-18-2020, 05:02 PM | #1 |
3570
Rep 10,351
OEM N55 Valve cover. Experience?
The N55 has been used in so many models I figured posting here would cast the widest net.
I need to replace the gasket and at 60k miles I don't want to have to pay a shop to go back in at 70k, 80k miles over a cracked cover or failed PCV so I'm looking for experience with the service life of the non-genuine part. It appears that there are about three suppliers at 1/2-2/3 cost of the Genuine BMW part with 2-3 yr warranty. Comment away and TIA.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
02-18-2020, 08:24 PM | #2 | |
Rep 383
F32Fleet3570.00 |
02-18-2020, 08:39 PM | #3 |
Rep 139
Had an Indy replace my gasket about 4 years ago. Sorry I didn't replace the valve cover then. Just replaced the valve cover and used a BMW oem valve coverfrom FCP Euro.
I wouldn't mess around with after market valve covers. Do it once and do it right. |
F32Fleet3570.00 |
02-18-2020, 11:24 PM | #5 |
Rep 1,934
https://www.amazon.com/gp/product/B0...UTF8&psc=1
And an oem gasket. It's a Mahle vc with the logo covered. The Mahle is an OE with the bmw logo covered. The oe is just a Mahle with a bmw logo. There are so many instances of this kind of parts supply chain in our a cars and all major manufacturers. Can't post the FB thread where many people have used the above combo with no problems.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
F32Fleet3570.00 |
02-19-2020, 06:25 AM | #6 | |
3570
Rep 10,351
02-19-2020, 07:16 AM | #7 | ||
Rep 445
02-19-2020, 07:23 AM | #8 |
Rep 1,934
Yeah the vac port is due to auto or manual I believe, not the turbo.
02-19-2020, 08:42 AM | #9 |
Rep 445
02-19-2020, 08:44 AM | #10 |
Rep 445
OP, realoem shows one PN 11127570292 that runs from 2008-2019 on various chassis https://www.realoem.com/bmw/enUS/par...&q=11127570292
If I were set on replacing the whole thing I would just go Mahle for the cover and gasket since its the OEM. |
02-19-2020, 10:04 AM | #11 |
Rep 288
I have a small oil leak at the back of the block that drips on my downpipe.. I'm at 69K, do I just do the entire valve cover since I'd have to do the gasket anyway?
02-19-2020, 11:18 AM | #12 |
Rep 688
Drives: 22 TR X3MC
Replace the Gasket
2022 X3M Comp
2013 335i xDrive (Sold) |
02-19-2020, 12:12 PM | #13 |
Rep 139
Do both now. Otherwise you will have to change the valve cover later like I did. Do it once and do it right.
02-19-2020, 12:49 PM | #14 | |||
3570
Rep 10,351
02-19-2020, 08:22 PM | #15 | ||||
Rep 1,934
02-22-2020, 07:53 PM | #16 |
Rep 819
Drives: Bmw 335i f30 N55 ( sold)
I had the same as you and had Bmw do my valve cover under warranty. They fail as miles go up so better off just doing it
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
