03-27-2017, 12:02 PM | #155 |
Rep 82
Hey guys, for clarification
If you only do LCA, the wheel will not be centered & No custom spacers required. Spacers only required for the Tension strut. If you do the struts with the LCA & the spacers. the wheels is centered is this correct?
@theyoungcarmody
2015 m235i track edition PTF / Bm3 n55 dev car / brand ambassador Cscs time attack - street rwd Who says a race car can’t also be a show car?!?! |
03-27-2017, 12:13 PM | #156 | |
Rep 1,084
However, I found that a 1-1.5mm spacer (really, just a washer) helps the LCA fit better than without.
03-27-2017, 12:23 PM | #157 |
Rep 82
where do you put the washer for the LCA? in front or behind (push forward or move back) or is this just to reduce play?
@theyoungcarmody
03-27-2017, 12:31 PM | #158 |
Rep 1,084
in front of the LCA, but I don't think it matters, I just wanted it in the same place on both sides
03-27-2017, 01:01 PM | #159 | |
Rep 82
Excellent thanks for clearing things up for me
@theyoungcarmody
04-23-2017, 07:28 AM | #160 |
Rep 62
TS's and Bimmerworld F80 bearing kit are going on this week for me. I already have the LCAs.
I think I read that an alignment is not needed after the TS install. Can someone confirm? |
04-23-2017, 10:46 AM | #161 |
Rep 5,262
I would think that any suspension change would require alignment but maybe somebody more knowledgeable can comment
04-23-2017, 11:08 AM | #162 |
Rep 1,084
I can confirm that toe doesn't change enough to need an alignment if you're just adding TSes.
05-06-2017, 01:56 PM | #163 |
Rep 1,370
05-06-2017, 09:40 PM | #164 | |
Rep 1,084
LCAs by themselves increase toe noticeably, putting TSes on top of LCAs had zero or near zero effect in my case
05-07-2017, 04:02 AM | #165 |
Rep 4,518
05-07-2017, 10:32 AM | #166 |
Rep 1,370
I never evaluated the car with one or the other. Once both were on it was very clear toe in was an issue. I doubt it's due to model difference but then again the car had not been aligned for almost a year. Could bad alignment account for the difference?
05-07-2017, 05:50 PM | #167 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
If you did both at the same time, then it was the LCAs that drastically affected the toe, while TSes had negligible affect.
05-08-2017, 02:57 AM | #168 |
Rep 4,518
Correct - well said DVC !
Current '22 X3M LCI.. |
07-03-2017, 07:46 PM | #169 | |
Rep 58
Thanks for the info everyone and for listing the part numbers. Decided this is the way I'm going instead of camber plates. Can anyone please share labour time to fit lca's and ts? Going to get it done at the same time. Cheers |
07-04-2017, 05:01 AM | #170 |
Rep 5
Hi. Do you guys know, whether a poly bushing for either m235i lower control arm (part No 31106857329/330) or M3 (part No 31122284529/530) exists?
I couldn't find one neither a Superpro nor a Powerflex. Only for tension strut arms. I'm gathering parts for a massive upgrade of front and rear suspension and this is the only part I haven't found yet. Thank you for your help. |
07-04-2017, 01:32 PM | #171 | |
558
Rep 1,477
Drives: 335i
Polo088161610.00 |
07-04-2017, 02:30 PM | #172 |
Rep 5
You are right. I was hoping that there would be something available for the m235 LCA, keep my strut with a poly bushing and my wheel centered. Camber will be addressed with the Millway camber plates. Thank you.
07-05-2017, 04:09 AM | #173 | |
Rep 4,518
Superpro camber adjustable bushes for F2x series - part no SPF4303K http://www.superpro.com.au/find/supe...999501544/vid- If doing LCA - I'd also suggest you do caster adjustable TS bushes to match - superpro part no. SPF4306K http://www.superpro.com.au/find/supe...999501544/vid- Likewise Powerflex now do LCA and TS bushes in both yellow [street/track]or black [race] https://www.powerflex.co.uk/road-ser...s+-3304/1.html LCA - either PFF5-1902 [fixed] or PFF5-1902G [camber adjustable] TS either PFF5-1901 [fixed] or PFF5-1901G [caster adjustable]
07-06-2017, 02:18 AM | #174 | |
Rep 5
Thank you for taking the time to search and offer suggestions. Powerflex item PFF5-1901G fits and have actually order it, but item 1902G does NOT fit. It is made for lca No : 31126852991 ,where as M235i lca is part No:31106857329. As far as Superpro AU, since the don't list series 2 , I have contacted them to confirm if items 4303k and 4306 fit m235i and their reply was : " I have forwarded your email below on to SuperPro Europe who will be in contact shortly". I hesitate to buy something that may not fit, so I adressed to fellow members for their kind help. |
07-06-2017, 03:17 AM | #175 | |
Rep 4,518
