07-04-2015, 05:40 PM | #23 |
Rep 986
1. 710's are Gunmetal all day long. Silver and Black would've looked silly. Gunmetal is perfect with these dusty brakes.
2. M235i RWD and Xdrive stock height is the same... Although it has not been confirmed if wheel clearances are different. The reason i say this is because the RWD and xDrive have LCA's that are different. I've confirmed from researching camber options for the fronts 3. You need to do the math. Every change to the car results in a change in potential clearances for wheel fitment. Specifically camber, wheel diameter, and width. It also depends very much on how you are driving the car! If the suspension has to travel full extents from track excursions, or if your just doing some daily commuting. There's a ton of people running F22's w/ 19's on lowered springs. But i highly doubt they are tracking this car. If you look in my pictures there is plenty of space for a 19 and if you size it right there is little difference in overall height / diameter (245/30/19 vs 245/35/19).. The real issue with this car is the offset/backspacing of the wheel to strut/fender. It's an odd fitment, and adding more width is limited before it hits. We try and stuff the wheels in using more negative offset to bring the wheel towards the wheel hub/inside fender, this gives us more room to push the bigger sized tire outside towards the edge of the outside fender lip. Here is a nice read http://www.moderntiredealer.com/chan...el-offset.aspx Last edited by zipphreak; 07-04-2015 at 08:51 PM.. |
BM235iW97.00 |
07-04-2015, 11:39 PM | #24 |
Rep 6,937
Drives: 2018 M2 AW DCT
I'm probably going to get VMR 710s. Mitch has suggested 18 x 8 1/2 ET 35 for a square setup.
07-05-2015, 12:08 AM | #25 |
Rep 1,503
07-05-2015, 09:12 AM | #26 |
Rep 6,937
07-05-2015, 09:42 AM | #27 |
Rep 5,262
07-06-2015, 02:06 PM | #30 |
General
2040
Rep 25,989
Good stuff, thanks for sharing Paul! Glad to hear the 265s worked out well
VMR|Wheels | 714.442.7916 |
07-18-2015, 12:38 PM | #31 |
Rep 1,503
OP, are you looking to do any lowering springs or coilovers? I'm anxious to see if you will still won't have rubbing issues.
FBO M235i r
F80 M3 |
08-18-2015, 10:03 PM | #33 |
Rep 228
Just had 265 rear and 235 front put on. Loweres on h&r, fits good
whoismorggan553.00 |
10-26-2015, 09:34 PM | #37 |
Rep 860
Paul, I'm thinking of doing the exact setup that you have, except with Michelin PSS tires (and I have a convertible rather than coupe). How would you say the everyday ride and handling compare to the OEM wheels and tires that came on your car? Many thanks for sharing all your learnings.
10-27-2015, 05:46 AM | #38 | |
Rep 596
10-27-2015, 11:26 PM | #39 |
Rep 1,503
Did you have to roll your rears for that?
FBO M235i r
F80 M3 |
06-29-2017, 10:54 AM | #40 |
Rep 22
https://www.flickr.com/photos/36296510@N00/35444108242/I ran 265/35/18 PSS in the rear with coilovers and it rubs now..
gonna set the camber to -2.5 and see if it works, right now I am@-1.6 |
06-29-2017, 11:00 AM | #41 |
Rep 22
07-05-2017, 05:23 PM | #42 |
M-OCD
17
Rep 38
In europe they advised me VMR710 8,5j ET43 for front and 9,5J ET50 rear. Now i decided to have the current PSS 225/40/18 (they look stretched) replaced by PS4 235/40/18 (these are not in PSS) unfortunately). To my discovery this combination only fits with a 10mm spacer! Otherwise the tire will hit the shock, even with a 5mm spacer. Any ideas? I really don't want to use spacers...
12-03-2017, 10:10 PM | #44 | |
Rep 145
Front: 18x8.5 +45 w/ Michelin 235x40 18 Rear: 18x9.5 +58 w/ Michelin 265x35 18 I run with 3mm spacers all 4 corners. Only issue on fronts, my front fenders are not rolled and I have experienced rubbing if the wheels turned real hard on uneven surface. I have not experienced rubbing with Michelin 225x40 18 tires on the same rims. |
