11-14-2018, 06:39 PM | #1 |
Rep 24
2018 M240i Convertible Spare Tire
Hi... First time poster. Just bought, and am waiting for delivery of, a 10,000 mile 2018 M240i Convertible. It is Certified Pre-Owned, and I will have about 4 years or 100,000 on the warranty. I’ll post pictures after I get it.
The car already has Michelin Pilot Super Sport tires on it. As there is no default spare in the car and I don’t think these are run flats, are there suggestions for any type of spare that might reasonably fit in the very limited trunk? I know there is a pump and assumably some gunk to pump into the tires. Any other suggestions for a new owner that should be considered day 1? Thank you! |
11-14-2018, 06:46 PM | #2 | |
Luxury at the redline :)
9105
Rep 7,563
http://www.bimmerzone.com/BMW_Perfor...2M235-KIT.html |
11-14-2018, 07:01 PM | #3 |
388
Rep 889
If you put that in your trunk you won't have room for one rollaboard suitcase, much less even the smallest member of your support staff that one likes to keep back there.
I was pretty nervous about having no spare but day in and day out I've gotten over it. That said, when these tires wear out, I will very likely go for run-flats. They've saved my bacon a couple of times. |
11-14-2018, 07:07 PM | #5 | |
Rep 24
11-14-2018, 07:50 PM | #6 |
M240iCVDriver
Rep 23
I took the run flats off my car and changed to the Michelin Super Sports.... so much better tires and not nearly as expensive as the run flats. I got a spare Bavarian Autosport and kept it in the trunk and when I needed more trunk space put it behind my seat.
no problemo.... lol |
11-15-2018, 08:23 AM | #8 | |
Rep 2,067
2019 X2
dradernh4377.50 Unicorn123186.50 |
11-15-2018, 08:43 AM | #9 |
Rep 69
Drives: 2014 M235i AW
I have repaired a tire curbside twice using a simple tire repair kit. I keep one in the car along with a compact pump that really pumps - 90 seconds to full inflation. The real pump makes it so I can feel air coming out of the tire damage. Between that, the BMW goop and my cell phone to call a family member to bring a spare tire, I'm hoping I'm covered. Still a risk. The real spare takes up too much space unfortunately.
2014 BMW M235i AW
1998 Porsche 911 2007 Mercedes E350 Wagon 2001 Toyota MR2 1977 Lancia Montecarlo 2002 Acura RSX Type S |
11-15-2018, 12:12 PM | #10 |
Rep 129
My old F30 3er had run-flat summer tires and no spare. Hated the tires. I even got a flat and the run-flats didn't hold up long enough to get me to the dealer. During the winter I had regular rubber and just kept a Conti Kit in the trunk. No issues.
My F23 m240i converti has MPSS, and comes with its own Bmw tire pump/patch kit incase you get a flat. All else fails, call Bmw concierge. |
11-26-2018, 02:45 PM | #12 | |
Rep 1,154
11-27-2018, 09:51 PM | #13 |
Rep 369
I'm on my second F23 convertible. I carry the Dynaplug in my trunk. Works great. Just used it on my wife's Jag.
http://www.dynaplug.com/ultralite_xtreme.html |
11-28-2018, 10:19 AM | #14 |
Rep 6,027
She shouldn't be driving around construction areas so much!
11-28-2018, 11:24 AM | #15 | |
Rep 69
I've used an old school kit with reamer, glue and rubber plug.
2014 BMW M235i AW
11-29-2018, 10:04 AM | #16 |
Rep 202
This Cadillac ATS complete kit with the same tire is about $200 less and the tire/wheel alone about $70 less than the bimmerzone offer.
The aluminum wheel even looks like it might be better and the kit comes with a real case. I have not bought one yet but plan to. https://modernspare.com/search-page/...o=ATS&cfy=2017 Last edited by Rocky58; 11-30-2018 at 12:08 PM.. |
11-29-2018, 10:13 AM | #17 | |
Rep 823
BMW - 72.6mm Cadillac - 70.3mm |
11-30-2018, 11:28 AM | #18 |
Rep 95
I initially looked into the smaller size spare tire, but it wasn't that small and, once on the car, couldn't be used for much distance. I decided to go with a full-size tire that would take up somewhat more of the trunk but could actually get me home even if the flat happened on a highway 150 miles from my house (which is where I got my last flat). When I was ordering two sets of wheels from Tire Rack, one with summer tires and one with winter tires, I ordered an extra wheel with an AS tire mounted on it.
This does take up most of the trunk, especially because you also have to carry around a jack and some tools, but it gives me a lot of peace of mind. When I get groceries or have other stuff to haul, I just stick the stuff in the back seat. Last edited by ctemkin; 11-30-2018 at 02:32 PM.. Reason: type |
11-30-2018, 12:01 PM | #19 |
Rep 202
No, I'm sure you're right. But the way it has been explained to me is that aftermarket donut spare wheels are rarely made specifically for one car and center bore size. The bimmerzone one, for example, comes with a centering ring. At the speed and conditions I use a donut spare, I would not have a problem just mounting it with lug centering, i.e. without a centering ring. If it was a concern, a ring is a two-dollar piece of plastic.
11-30-2018, 02:19 PM | #20 | |
Rep 823
11-30-2018, 03:26 PM | #21 | |
Rep 202
I checked with the manufacturers and they assure me it will fit the M240i and fit over the larger brakes. "Good news, our wheel actually has a Center Bore of 72.6, so it will be both hub centric and lug centric for your vehicle." I'll post a review when I get it. Last edited by Rocky58; 11-30-2018 at 05:48 PM.. |
