06-19-2021, 03:10 PM | #111 |
Rep 725
What's the username of Hamilton's largest fan on this forum? He's unusually quiet now that Verstappen is consistently outperforming Hamilton. Like I and many others have said, it's primarily technology, not the driver, that is most directly attributable to winning F1 championships. No way Sir 7ewis wins that many championships if he and Verstappen race on the same team or if Hamilton and Verstappen switch teams (Schumacher doesn't either by the way). I genuinely don't care for either driver, just don't understand biased fans who exclude the validity of the technology argument because they can't get past their passion for a particular driver. Technology gaps are evident at the top of the field and even more between between top and bottom teams.
That said, maybe Hamilton fell off this year, while Max has evolved, but seriously? This isn't the Stallone Driven movie. |
06-19-2021, 03:40 PM | #112 | |
General
63406
Rep 24,687
Well said mate , and I agree completely !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-19-2021, 03:54 PM | #113 | ||
Rep 725
///M Power-Belgium63406.00 |
06-19-2021, 03:58 PM | #114 |
General
63406
Rep 24,687
Of course mate ,but I'm pretty sure "something 'really changed" !
•MAX wins races •MAX pulls the pole •MAX beats 7Hammy in the rain (check Imola) •MAX is the leader (P1) in the driver rankings
M5Rick60135.50 |
06-19-2021, 04:10 PM | #115 | |
General
63406
Rep 24,687
2 weeks ago at the Monaco GP , he said he was traveling While MAX won at Monaco , and 7Hammy failed through the whole race .. But honestly , I can feel his pain ! It's the same pain that we/I could feel in the last 5 seasons during the Benz domination !
M5Rick60135.50 |
06-19-2021, 04:46 PM | #116 |
Rep 3,531
///M Power-Belgium63406.00 M5Rick60135.50 |
06-19-2021, 04:59 PM | #117 |
Rep 1,184
06-19-2021, 05:15 PM | #118 | |
Rep 3,531
06-19-2021, 05:24 PM | #119 | |
General
63406
Rep 24,687
#Arnie
Killed by Death12474.50 M5Rick60135.50 |
06-19-2021, 05:28 PM | #120 |
Rep 3,531
06-19-2021, 06:10 PM | #121 | |
#buildnotbought
10862
Rep 4,895
The point is that if you can adjust toe, you can adjust it to higer top speed on the straights (less toe angle=less tyre friction=more efficiency) and more grip in the corner (more toe angle) (especially during braking). You saw them mostly changing their toe at the end of a straight before entering the corner. THey change their toe from staightline setting to corner setting. They do that with only one intent, that the one setting works better in a straight line and the other in corners/during braking. The setting in a straight line has only one goal (there is only one goal in the straight: top speed) Fact of the matter is that for now it looks like the supremacy of the MERC's is partly gone and to me all rule changes effect all cars except the banning of DAS. As the chassis have been carried over from last year due to covid, the changes on the cars are very very little compared to normal season changes, so that RB has made such a gain on MERC shows something. Merc has lost it's edge (and 'coincidentally' also their very controverisal DAS system)
06-19-2021, 06:34 PM | #122 | ||
i'm just saying
5749
Rep 2,634
for optimal top speed and braking, fronts needs to adjusted to toe out and rears toe in.. angle depends on the car.. not 0.. its a racing setup 101.. so after this in mind.. have you seen Merc's playing with DAS when they re in a "hot lap" for that purpose you re talking about? if so, i d like to see the footage please.. PS: see im kind and not expecting you to be in the car during that hot lap footage GuidoK..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
inTgr8r2431.50 |
06-19-2021, 07:18 PM | #123 | |
#buildnotbought
10862
Rep 4,895
The specific explanation starts at 1:45 zero toe gives more straight speed. Less scrub on the tyre patch. and, zero toe also makes the car front narrower. better aero. But indeed, not racing 101 but racing 102. In the end changing the toe can also be used to get extra heat in the tyres at specific patches which can be important in braking and cornering (but of course that takes energy, thus less speed) Obviously you're not going to set up a racecar with 0deg toe if you dont have DAS, so maybe you're confused by that with your racing 101 booklet. You can also clearly see in the video that when entering the straight he pulls the steering wheel. Pulling on the wheel decreases toe out. (you can see both happening in the video at 0:11 when he starts his run on the straight) Zero toe on the straight gives the least rolling resistance (=better top speed), the least aero drag (=better top speed) and the least tyre wear. But it all doesn't matter, we've seen that HAM couldn't pass PER time after time on the very long straights of Baku despite having DRS every time. So they've lost top speed. Coincidentally with their DAS system.... All the specific benefits MERC seemed to have over their competition in the last 2 years (top speed while able to corner fast and very little tyre wear) are also benefits that the DAS system can enhance.
06-19-2021, 07:54 PM | #124 | |
Rep 535
It’s made the races much more interesting to watch this year, but please don’t fool yourself thinking RB has gotten that much faster. They just didn’t lose as much time with the aero changes as MERC. I’d have to dig up the videos, but the MERC engineers figured they lost 3-4 seconds a lap with the aero changes and had to try and gain that back. Again should be a good race tomorrow…hopefully MAX can take better care of his tires tomorrow
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey Previous: 2016 328 xDrive Alpine White |
Killed by Death12474.50 yco5748.50 |
06-19-2021, 08:15 PM | #125 |
#buildnotbought
10862
Rep 4,895
the banning of DAS systems dont effect all cars, just mercedes.
All the other rule changes apply to all cars. Of course different teams adapt with different succes to those changes. But it's strange that MERC had more trouble adapting to rule changes. First of all because the changes are very small compared to other years because the chassis have been carried over to this year, and secondly MERC used to be the team that was most ahead of other teams at the beginning of the season. So they had the least trouble getting their car fast early in the season. Now thats different. Maybe MERC is better in developping a completely new chassis than evolving an existing chassis (which is more the case this year) Or maybe losing DAS has lost them the edge.
06-19-2021, 11:18 PM | #126 | ||
i'm just saying
5749
Rep 2,634
i was trying to emphasize hot lap somehow above as well but it didnt work.. Quote:
i ll paste the link below and i believe you ll still say it was the DAS made Merc' lose 1.5 seconds at the very same track comparing to last year.. Lewis Hamilton 2020 quali time.. 1:28.319.. Lewis Hamilton 2021 quali time.. 1:30.248.. Max Verstappen 2020 quali time.. 1:29.409.. Max Verstappen 2021 quali time.. 1:29.990.. https://www.formula1.com/en/results....ualifying.html .. as you can see Merc' lost 1.5 seconds.. RB lost 0.5 at the very same track.. deficit is 1 second.. its not strange its physics.. if you want to close your eyes to these facts, im sorry i dont believe the earth is flat as well.. cheers..
06-20-2021, 02:40 AM | #127 |
General
60136
Rep 19,583
///M Power-Belgium63406.00 Killed by Death12474.50 |
06-20-2021, 02:57 AM | #128 |
General
60136
Rep 19,583
FIA are not saying anything about a front wing test,I've seen the Merc front wing as I'm sure many have with the the winglets rising up at speed.
Horner has called for a test in line with the one on rear wings in force now and FIA must end their feet dragging when it comes to getting Merc in line with the others, a glaring example is allowing them to keep DAS for a whole season ruling it illegal when Merc could easily change back to conventional steering. |
06-20-2021, 04:10 AM | #129 | |
General
63406
Rep 24,687
Your QF times means actually nothing ! All the 2021 cars run faster than last year ..Even Ferrari ! Sainz ran with his Ferrari 344 km/h on the Baku straight ... •The mistral wind ! In other words : This season It's the strong mistral wind at the Paul Ricard circuit . I already mailed this morning with my nephew in France. He said over this weekend the wind is unpredictable and is constantly changing... That's why the cars run slower than last year . Today the wind blows even harder ,mate that's bad news for 7Hammy ! "EDIT & UPDATE" '75% chance of rain (thunderstorm is possible) at 01:00 PM !
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 06-20-2021 at 04:35 AM.. |
M5Rick60135.50 Killed by Death12474.50 |
06-20-2021, 04:54 AM | #130 | |
i'm just saying
5749
Rep 2,634
and they re not my lap times.. one of them belongs to Max.. tell him what you re saying..
06-20-2021, 05:01 AM | #132 | |
General
63406
Rep 24,687
In other words :On this track ,faster or slower lap times are depending of the mistral wind strength . Do you understand ?
