2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding VIM for Nbt Evo system ?
      05-10-2015, 09:23 PM   #1
Rexmachine
Drives: M5 F10, M3 Com, M235 cabrio
Anyone managed to crack the latest NBT evo system ?
Mine 2015 April M235 cabrio is using NBT evo, my installer cant crack the VIM. even he found the codes but it doesn't let him replace it.
Please help thanks
Cheerios
Reeve
      05-10-2015, 11:02 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Please help thanks
Cheerios
Reeve
what VIM? not sure what you mean....
      05-11-2015, 12:57 AM   #3
Rexmachine
Video in motion, it for the DVD player to be playing even when car is moving so my kids can watch their favourite cartoons.
      05-11-2015, 01:01 AM   #4
pikcachu
pikcachu's Avatar
1403
Do you know which coding he applied ?
you need all these:
DVD speedlock part1 Yes HU_NBT 3000 SPEEDLOCK_X_KMH_MIN value = FF
DVD speedlock part2 Yes HU_NBT 3000 SPEEDLOCK_X_KMH_MAX value = FF
Video handbrake Yes HU_NBT 3000 VIDEO_HANDBRAKE nicht_aktiv
Video front locked Yes HU_NBT 3001 VIDEO_FRONT_LOCKED nitch_aktiv
Video handbrake or Park Yes HU_NBT 3000 VIDEO_SPEEDLOCK_CONDITION none
      05-11-2015, 01:30 AM   #5
Rexmachine
you need all these:
I know he cant even change the codes , it is like locked by BMW new NBT Evo system
      05-11-2015, 09:54 AM   #6
Rexmachine
Ok another workshop solved my issues coding for video in motion done thanks
      05-18-2015, 10:34 AM   #7
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
HU_NBT2 is the same as HU_NBT coding wise.
I think your guy didn't know how to work around the trimmed files when the other shop did.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      10-04-2016, 05:18 AM   #8
deliciouscars
Drives: f11
No this coding is not the same....!!!
Hello guys I need help, so I have changed the value in
HU_NBT2 => VIDEO_HANDBRAKE => nicht_aktiv
HU_NBT2 => VIDEO_FRONT_LOCKED => nicht_aktiv
HU_NBT2 => VIDEO_SPEEDLOCK_CONDITION => none
HU_NBT2 => SPEEDLOCK_X_KMH_MAX => Werte = FF
HU_NBT2 => SPEEDLOCK_X_KMH_MIN => Werte = FF
HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MIN => nicht_aktiv
HU_NBT2 => SPEEDLOCK_SPEEDVALUE_MAX => nicht_aktiv
HU_NBT2 => SPEEDLOCK_CAR_STANDSTILL => none
But this function don't work on my car, and the value SPEEDLOCK_SPEEDVALUE_MIN and SPEEDLOCK_SPEEDVALUE_MAX don't find in my car.
Thanks for zur help
Best regards
      12-01-2016, 04:03 PM   #9
japanaltaf
Drives: 2019 AW X3 M40i
I have a 2017 F87 and also wasn't able to initially find
SPEEDLOCK_CAR_STANDSTILL set to: none (default value)
SPEEDLOCK_SPEEDVALUE_MIN set to: nicht_aktiv
SPEEDLOCK_SPEEDVALUE_MAX set to: nicht_aktiv
So I updated my E-Sys, Launcher and psdzdata files and they magically showed up!
However, even after setting all the values, I still can't play videos in motion. I will try setting these (as suggested in another thread and hopefully that will allow me to play them up to 63 kph) -
SPEEDLOCK_SPEEDVALUE_MIN werte = 1F
SPEEDLOCK_SPEEDVALUE_MAX werte = 3F
      12-02-2016, 03:16 PM   #10
japanaltaf
Just wanted to confirm that using these -
3000 -> VIDEO_HANDBRAKE set to: nicht_aktiv
3000 -> VIDEO_SPEEDLOCK_CONDITION set to: none
3000 -> VIDEO_FRONT_LOCKED set to: nicht_aktiv (default on my car)
3000 -> SPEEDLOCK_CAR_STANDSTILL set to: none (default on my car)
3000 -> SPEEDLOCK_SPEEDVALUE_MIN werte = 1F
3000 -> SPEEDLOCK_SPEEDVALUE_MAX werte = 3F
3006 -> SPEEDLOCK_X_KMH_MAX werte = FF
3006 -> SPEEDLOCK_X_KMH_MIN werte = FF
I am able to play videos in motion up to 63 kph. Thought it may be useful as yet another confirmation for those who have a 2017 model with iDrive 5
      12-03-2016, 10:25 AM   #11
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
ID4 can be played above 63kph.
ID5 is only up to 63kph.
      12-05-2016, 07:06 PM   #12
Gabrola
Gabrola's Avatar
191
Drives: 340i
It can be done on ID5. I think it's something along the lines of editing the CAFD/NCD manually to change the value and adjusting the signature to match.
      04-15-2017, 03:58 AM   #13
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
VIM on ID5 is possible without any messing around with signatures or other shenanigans.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      04-15-2017, 09:59 AM   #14
Dtwok335
Germany
16
Drives: M3F80-Frozenblack-metallic
I Coded my M240i today playin with that Video in motion. So I can tell that it's right.
Speedvalue min 1F and Speedvalue 3F allows you to Play Videos till 63kph. So I think the solution is to do it like on the E series, with Coding The Netto Dats. So you have to Work on that file manually.
Would appreciate your suggestions.
      04-15-2017, 12:54 PM   #15
Wibbles
Wibbles's Avatar
445
Drives: M3LR
None of that is required to code VIM on ID5 correctly
      04-16-2017, 02:02 PM   #16
Almaretto
Almaretto's Avatar
2374
Does your solution allow for Miracast or Manual in Motion as well?
      04-16-2017, 05:01 PM   #17
Wibbles
Wibbles's Avatar
445
Drives: M3LR
screen mirroring, yes.
      04-17-2017, 12:01 AM   #18
Gabrola
Gabrola's Avatar
191
Drives: 340i
If I may ask. How?
      04-17-2017, 01:36 AM   #19
Almaretto
Almaretto's Avatar
2374
But not user manual in motion as well?
      04-26-2017, 05:41 AM   #20
Wibbles
Wibbles's Avatar
445
Drives: M3LR
not the user manual
      05-09-2017, 02:34 AM   #21
GDLF.
Germany
14
Drives: 2019 G01 X3 M40i
wibbles Would you share your solution with us? Maybe via PN? Would love to code VIM on my M140i '16 with NBT2 ID5
      05-10-2017, 01:33 PM   #22
Wibbles
Wibbles's Avatar
445
Drives: M3LR
I'd love to tell you but it is a trade secret
