09-17-2021, 11:39 PM | #1 |
Rep 21
Drives: BMW M2C
ACSM Faults Codes HELP!
Hey guys
I’ve removed my driver seat and coded out the airbags to get rid of the airbag errors. Coding of the ACSM FDL went well as there are no errors related to the seat. I do have an error though in ACSM as “code doesn’t match equipment” relate to the Central Sensor (yaw rate) that I never touched as the only thing that was done is setting to nicht_aktive the seat airbag Tried clearing errors with Tool32 - no luck Tried Locking the ACSM with Esys - no luck Tried to lock the ACSM with tool32 and I get a “ECU CONDITIONS NOT CORRECT” message… CAFD files have been reset already to VO and all 3 of them are in ACSM and have the green light, no errors in FDL coding Running out of things to do to fix that “code doesn’t match equipment… 😭 Pls Help! TIA!
F87 ///M2 Competition '19 Alpine White
09-19-2021, 06:43 AM | #2 |
Rep 21
Drives: BMW M2C
[SOLVED]
For some very weird reason, the ACSM when coded needs to have the factory VO setup, specific it needs in my case 2VF (adaptive suspensions). I previously coded out my adaptive suspension, and 2VF was removed from the VO. This triggered the “coding don’t match equipment” and the errors with the central sensor that couldn't be cleared with Tool32 Solution: - Added back 2VF in the VO - Factory coded ACSM - Coded FDL to remove the airbag ONLY, Sitzairbag_Thorax_Fahrer --> nicht_aktive (I'm keeping the seatbelt buckle connected to the car) - Cleared codes with Tool32 0 Error Found in ACSM and no code at all anywhere in the car
