2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Intelligent Safety, don't think it's working
      09-02-2021, 10:26 PM   #1
nazali
nazali's Avatar
159
Drives: car
so, not sure if this has ever worked,
I have apparently
544 Cruise Control With Braking Function
5AS Driving Assistant
So the only thing that happens when a car cuts in front of me or I get too close is a get the red car symbol in the dash, and bugger all else. The symbol at some stage is supposed to flash and sound an alarm, I mean even if it doesnt brake , I don't know unless I'm looking at the dashboard. It's on, as the switch shows green
with cruise control, same thing, doesnt brake.
I've looked in the manual (see below) I set the idrive all things to on and early detection, but nothing ? any ideas
Approach control warning
Depending on the equipment, the approach
control warning system consists of one of the
two systems:
▷ Approach control warning with City light
braking function, refer to page 133.
▷ Approach control warning with light braking
function, refer to page 136
The system sounds a warning before an imminent
collision and actuates brakes independently,
if needed.
The automatic braking intervention is done
with limited force and duration.
A camera in the area of the rearview mirror
controls the system.
The approach control warning is available even
if cruise control has been deactivated.
Symbol Measure
Symbol lights up red: prewarning.
Brake and increase distance.
Symbol flashes red and an acoustic
signal sounds: acute warning.
Brake and make an evasive maneuver,
if necessary.
      09-02-2021, 10:32 PM   #2
nazali
nazali's Avatar
159
Drives: car
what also concerns me, is I found these errors today on ista, I cleared them out and they went, underlined, which I think is relevant to the system
      09-03-2021, 01:16 PM   #3
nazali
nazali's Avatar
159
Drives: car
no replies
S'ok guys' LOL hahaha
As the car is under warranty, I've booked it in with BMW,
I spoke to my parts guy and he confirmed that I have
from my vin, so ???
can't see any radar under the front bumper although I did do a number plate relocate but doesn't seem to be blocking anything, can't see any sensors and there is the camera for the connected drive
      09-03-2021, 04:10 PM   #4
jzeiler4
Drives: 2021 M240i xDrive vert
Cruise control with braking just applies the brakes if you are going down hill and exceed the speed you set in the cruise control. Mine (2021 M240) does it all the time, it is subtle, but noticeable. Compared to our 2018 Pacifica which just keeps down shifting until you finally get some engine braking at near red line, which I hate.
The radar in the grill (which the 2 series does not have) is for the adaptive cruise which keeps you a set distance from the car in front regardless of the speed you set in cruise control.
I have only seen the red car light up when on a curvy road where there was a vehicle that I would have hit if I didn't take the curve. No alarms so far.
      09-03-2021, 07:31 PM   #5
nazali
nazali's Avatar
159
Drives: car
txs man,
As a last ditch, I actually cleant the area in front of the windscreen, removed my 407 box and even my dashcam.
I checked all the settings in the idrive, it's there, I'll take a pic, it shows avoidance with breaking, but nada, I think something is broken, 4 sure.
NOW, the red car thing is not even coming up. the LED does come up on start up check, but now, even when I'm driving no red car.
I'll check the codes on it tomorrow, I cleared all codes and there were none this morning. Just to add, this has NEVER worked.only the lane change warning gizmo
ok realoem, shows 3 devices, there is a radar, but you can't see it, the camera in the windscreen, but that also does the lane detection and the speed detection which both works and there's another module. Relocating my number plate would not have effected anything
      09-14-2021, 12:14 PM   #6
nazali
nazali's Avatar
159
Drives: car
so in with BMW now, they are saying they ran a test plan and ALL is working fine, I asked if they did a road test they said no, LOL, I have it in for another issue (see my thread on concierge not working) there were errors in ISTA about some major fault that needed to be reported to the dealer LOL FROM ISTA
I hope they do a reflash
      09-14-2021, 12:37 PM   #7
nazali
nazali's Avatar
159
Drives: car
at least I know what i-level it is at
Search this Thread:
Copyright ©2000 - 2021, vBulletin Solutions Inc.
