VRSF intercooler received with damaged fins, scratched/dented |
09-15-2021, 05:59 PM | #45 |
Rep 301
Drives: BMW M235i
VRSF received the defective intercooler todya. I've still received no response from Top Gear Solutions to several emails regarding my refund in a week now.
Buyer beware with both VRSF and Top Gear Solutions. Go with X-PH or N54 Tuning if you want BMW performance parts. |
09-16-2021, 12:53 PM | #46 |
Rep 4,130
I'm guessing they are waiting on VRSF to process your return to issue a refund, but it's pretty crappy that they haven't communicated that to you. Keep us posted on the new IC and how the returns turns out. Sorry about the trouble dude, it seems like a headache.
Mods: Yes.
09-22-2021, 12:11 AM | #47 | |
Rep 145
11-05-2021, 09:37 AM | #48 |
Rep 301
Drives: BMW M235i
I finally got around to installing my ARM Motorsports intercooler. Everything I read said it could be installed from underneath and I tried for a while but eventually decided to remove the front bumper. After taking the bumper off, I removed the fan shroud hoping to reinstall it later. It wasn't fun taking the bumper off but far easier to install the intercooler. Once I had the intercooler installed, looking at the fan shroud, there's no way there was enough room to reinstall the fan shroud and I have no idea how people install the ARM intercooler from underneath as it seems there's not enough room with the fan shroud in place.
I hope without the fan shroud directing air towards the intercooler and radiators that they all are still efficient at cooling. I couldn't be bothered with taking any logs beforehand. There aren't a lot of places near me where I can get full rpm pulls in 3rd, 4th and 5th gears. Hopefully in the future I can find somewhere to log the ARM intercooler that's safe and where I won't get arrested. |
11-05-2021, 02:30 PM | #50 |
Rep 301
Drives: BMW M235i
I had intended to reinstall the shroud figuring it'd help direct air better but I don't see that there would be anyway to do so without significant trimming. I'm not even sure how it'd be able to be trimmed, in order to keep the mounting tabs which attach to the beams that hold the crash bar. The air shroud is fairly deep, at least 6" deep. With the ARM Motorsports intercooler being so tall and because it gets positioned in front of the radiator and some other radiator (or maybe the AC Condenser?) there was no room for the fan shroud. The front of the intercooler comes out just about even with the brake air ducts.
Before I had removed the bumper and air fan shroud, I was trying my best to shove the intercooler up there and make it fit but it was hitting against the shroud and then I noticed it was doing some scraping and fin damage to the radiator/condenser above and in front of the coolant radiator so then I decided I'd have to take the bumper off and eventually the air shroud. I feel like the air shroud would have helped with directing and forcing air through the intercooler but it seems that it could also block air from hitting the top of the taller portion of the ARM intercooler. |
AmuroRay2266.00 |
11-05-2021, 02:56 PM | #51 |
Rep 5,364
The shroud definitely helps. It's ridiculous that you can't fit the shroud and had to pull the bumper to instill this IC. Does this IC not even have tabs to hold the fan shroud in place? The joys of aftermarket parts.
11-05-2021, 03:36 PM | #52 |
Rep 301
Drives: BMW M235i
I probably should have gone with BMS but I liked the idea of the ARM intercooler having more frontal surface area and that people reported ARM was one of the better performing intercoolers for the money. I didn't know that the ARM intercooler had silicone coupler hoses which I'm not a fan of and it also didn't have the side tabs or the fan tabs to help positioning that other intercoolers have.
11-05-2021, 05:04 PM | #53 | |
Rep 4,130
11-07-2021, 12:00 PM | #54 | |
Rep 5,364
The ARM IC definitely seems geared towards max surface area and performance under hard driving, but compromises in other areas to keep the price low.
11-08-2021, 08:45 AM | #55 | ||
Rep 4,130
https://f30.bimmerpost.com/forums/sh...1869712&page=3 About your installation woes. 0-2 on ICs man, this is insane.
Mods: Yes.
grocerylist268.00 |
11-08-2021, 10:55 AM | #56 |
Rep 4,130
Followed up - The other person who bought one confirmed that it does not connect to the bottom of the intercooler.
I also checked ER - and this seems to be the case with theirs; http://evolutionracewerks.com/index....geViewsIndex=1 You are putting the underside shield back on right, when you commented on ducting, this is what I assumed you meant initially.
Mods: Yes.
11-08-2021, 11:42 AM | #57 | |
Rep 301
Drives: BMW M235i
Looking at the 335i post you posted, because of the 1-2" gap between the fan and intercooler, I'm wondering if I'll have issues when idling. I guess that might only be a problem if I were to drive the car hard then stop quickly idling for a while as the fan won't be able to suck air through the intercooler as efficiently. |
11-08-2021, 12:45 PM | #58 | |
Rep 4,130
Mods: Yes.
grocerylist268.00 |
11-08-2021, 03:27 PM | #59 | |
Rep 5,364
11-08-2021, 03:48 PM | #60 | |
Rep 4,130
In fact, bigger intercoolers like the Evo 3 are 7.5" in depth, pushing the fan further away from the upper stepped portion of the core, versus something like Evo 1 which is about 4-4.5" deep. No one is claiming the Evo 1 can outcool the Evo 3 in ANY scenario. No one is claiming higher coolant and oil temps as a result either. The only reason the fan is useful on a stepped intercooler is because the core is less effective the deeper it is (effectiveness on cooling is only 1/4th as efficient ) so the added airflow of the fan may help , but at lower speeds. On a core that's about 3" deep, there really isn't a benefit.
Mods: Yes.
11-08-2021, 06:06 PM | #61 |
Rep 5,364
I'm not concerned about the stepped portion of aftermarket ICs. The issue here is that the fan cannot be mounted correctly so that it can work as designed. The fan pulls air through the IC and radiator. Fans must be approximately 1" off the exchanger and mostly sealed or else efficiency is significantly impacted. For hard driving it's probably fine. Around town? I doubt it.
If the fan can't sit flush then I would bet the fan assembly is rubbing stuff up top and the upper fan brackets are under tension. That fan is over $500. ARM was simply lazy here. I feel bad for the OP because this part was sold fits like stock. That certainly isn't the case. |
11-08-2021, 07:08 PM | #62 |
Rep 301
Drives: BMW M235i
I hadn't considered that the fan could possibly be moving around stressing the fan bracket. Now I'm wondering if I should try to make some sort of spacer to keep it stationary relative to the intercooler and maybe some siding to cover the gap between the fan and intercooler.
11-08-2021, 07:12 PM | #63 | |||
Rep 4,130
This isn’t a problem for the ER/ARM because they are only 3” thick. Quote:
It’s sold as it fits and perform well - which it does. All you did is point out hypotheticals how how you think it should work and be designed. |
11-08-2021, 07:35 PM | #64 | |
Rep 4,130
If you want to, you can - but I don’t think it’s necessary, especially considering it’s actually mounted to the radiator itself (which is what hold it in place on the top and sides) Last edited by AmuroRay; 11-08-2021 at 07:40 PM.. |
grocerylist268.00 |
11-08-2021, 09:07 PM | #65 | |
Rep 5,364
grocerylist268.00 |
11-08-2021, 09:14 PM | #66 |
Rep 5,364
AmuroRay -
Just because people aren't reporting issues, doesn't mean the cooling system is working as designed. My guess is the fan will be running more and the electric water pump will be running harder. You are off your rocker if you think everything is working as designed and is what BMW engineers intended. Also, I challenge you to find me information stating that it's ok to have the fan sitting so far off the exchangers and efficiency isn't being lost. ER and ARM half-assed their designs. They choose not to set the inlet and outlets correctly to get the fan assembly to sit properly. Bigger isn't always better and race car parts rarely work well for street cars. These ICs are evidence of that. |
