07-26-2021, 12:04 PM | #1 |
Rep 42
xHP Flashtool Explained
Hi!
So this may be silly, but I know absolutely nothing about xHP and wanted to learn more. So at what point do you use a xHP transmission tune? I plan to be stage 2 in the near future (1-2 weeks) Is it beneficial to use xHP? what are the prerequisites? On their Instagram it says that the "BMW M240ix of steven_wedgeperformance with a 8HP70 transmission swap and xHP STG3. Running the transmission together with the B58 engine is enabled through custom mapping done by xHP. On build B58 cars the 8HP50 trans quickly starts to develop issues between 650 and 750 NM while the 8HP75 can hold this torque easily." And when asked how much they responded saying "From our side it's normal price, as we included that combination as standard car (B58/8HP70) in xHP. The swap itself of course depends on how much you can do yourself, cost for sourcing 8HP70 trans etc." ^What does this mean?! Everything sounds like rocket science to me at the moment with xHP. Once again this is my first BMW (m240) so I know nothing and I am trying to learn each and every day. Thanks for all the knowledge! |
07-26-2021, 12:21 PM | #2 |
Rep 410
Forget all the 8H75 stuff as that is a one off for big turbo etc.
For Stage 2 you either need a tune that "lies" to the stock transmission or lowers the torque so that the error codes are not triggered. XHP allows for higher torque, quicker shifting, change in up/downshift rpm .... so for Stage 2 I would always go XHP to make sure the Stage 2 Tune isn't hobbled by the stock transmission. |
07-26-2021, 12:30 PM | #3 | |
Rep 42
07-27-2021, 07:34 AM | #4 |
Rep 410
It should. Not sure aout the App but MHD has a choice between stock automatic <> manual/xhp so that the engine file doesn't need to fake or reduce torque. With xhp you get the whole milk vs skim milk Stage 2
07-27-2021, 09:46 AM | #5 | |
Rep 48
When I installed xHP, I did lose some burble (which I LOVED with BM3 in Sport/Sport+) on downshift, however flipping the ZF8 into M/S mode (stick to the left) and upshifts are simply intoxicating. I started xHP with Stage 2, but quickly went to Stage 3. Downshifts in Stage 3 are intense, but wonderful coming up to a stop light. My only next upcoming mod is a Remus axle-back for a little more growl, but otherwise this thing is a rocket ship and sounds like an F1. You won't be disappointed -- great combo. |
08-16-2021, 07:47 PM | #6 | |
Rep 452
Simply means there's no additional software cost for the transmission tune, you just pay their regular price for xhp. Its done that way because the donor transmission (8HP70) mentioned in the post already comes from another BMW (I believe a 5 series specifically, the screenshot you posted). The swap itself of course depends on how much you can do yourself, cost for sourcing 8HP70 trans etc." Means its up to you how much the physical transmission SWAP will cost (labor, parts, etc). In reference to your question of "how much". You CAN however use XHP tune on your stock transmission. You dont NEED to swap in another to utilize the benefits of the software. |
08-18-2021, 02:32 PM | #7 | |
Rep 42
Thank you so much for this break-down explanation. I learned a lot |
