07-24-2021, 07:38 PM | #1 |
Rep 3
Catted DP best burble options?
Hey everyone I just got the AA catted dp for a 2019 m240i and planning on getting mhd for a tune. Wanted to see what would be the best burble options? I heard it will wear out the cat quick if too aggressive.
07-28-2021, 11:01 AM | #2 |
Rep 86
From what I have read it can wear out the cat and the turbo, but the main reason I wouldn't do it is because the aftermarket burble tunes are so high pitched. The stock tune makes low pops, I personally hate how the aftermarket ones sound.
07-28-2021, 05:47 PM | #3 |
Rep 913
I actually de burbled my car - too many shitboxes have burbles now.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
07-28-2021, 08:24 PM | #4 |
Rep 348
I'd do oem aggression or off completely. Used to have AA catted dp and feel like even the stock burbles are aggresive enough to prematurely wear the cat. Went through 2 of those. I have catless now and turned it off completely.
07-29-2021, 11:11 AM | #5 |
Rep 558
In MHD I run "Soft", 0.3 sec in Comfort and 0.6 in Sport, min RPM 1600. I think it's 'just right'.
07-29-2021, 06:56 PM | #6 |
Rep 160
How does that compare to stock? Im looking forward to trying this or just turning it off once I finally receive my CG catted downpipe.
[Build thread] Mineral White | Cognac | 6 speed | Moonroof deletion
07-31-2021, 08:57 AM | #8 |
Rep 160
Anyone have any video clips with no burbles?
07-31-2021, 10:11 AM | #9 | |
Rep 190,750
if you hate burble best is off or you can be anywhere in between i recommend you test the different configs and select the one you like the best
07-31-2021, 07:24 PM | #10 |
Rep 3
but since is catted it would be better have it off? i do like the burbles though.
07-31-2021, 08:09 PM | #11 | |
Rep 190,750
Most recommend the default burble setting for catted DP
08-01-2021, 02:21 PM | #12 |
Rep 558
Less than stock.
08-06-2021, 01:20 PM | #13 |
Rep 864
NO Burbs Here - My Settings
Cold Start Delete - OFF
GTS Start-Up Roar - NO Burbles - OFF Although you can hear it often trying to burble. At Most OEM Burble with a Catted Downpipe -- is my preference. Just trying to save the Cat any harm. |
