07-13-2023, 02:29 PM | #1 |
Rep 239
Drives: '17 M240i 6MT
DinanTronics Sport - boost setting for 91oct?
I'm picking up a used DinanTronics Sport piggyback in a couple days, and I'm curious what settings other drivers use for it. Given the hot weather and California piss gas, I'm assuming the car's going to struggle with the +4psi setting. My plan is to try +2psi, +3, and then the full +4 on a tank of 91. After that, I'll trying mixing 91 with 2 gallons of E85 and seeing if there's any benefit. I've used this mixture before, but on stock tune, the need for more than 91 octane doesn't seem to avail itself, and I saw no power gains.
07-13-2023, 03:31 PM | #2 | |
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
07-19-2023, 01:54 PM | #3 |
Rep 239
Update: Race mode seems to work on 91, but the boost it achieves is a little inconsistent based on temperature and other factors. I've started adding 2 gallons of E85 to each full tank of 91 to average up to 93, and I'm not feeling it in the butt dyno, it's a nice bit of peace of mind until I'm back in the land of pump 93.
P.S: I'd confidently recommend this to anyone if you're able to find it on sale or used. I don't have experience with DME tunes [yet], but this is a nice stopgap between stock and Stage 1. It's not radically quicker, but I feel the kick in Race mode. |
07-19-2023, 02:49 PM | #4 | |
1296
Rep 3,533
SpencerC_6MT197.00 |
07-24-2023, 12:53 PM | #5 | |
Rep 190,807
The DME lowering timing means that the map is too aggressive for your gas. I recommend using a lower map that's more consistent with 91
07-24-2023, 01:06 PM | #6 | ||
Rep 239
For example, I'll floor it in 2nd making a right turn at a green light. 1500-4500 RPM, feels like valet mode. 4500 hits, and it abruptly increases boost to the expected. Clutch in, shift to 3rd, issue is gone. It's hard to predict when it'll happen, but I'm chalking it up as a consequence of adding boost without changing timing. Octane issue would feel slow throughout, or the boost would gradually increase instead of a sudden jump.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
