06-20-2023, 10:43 PM | #1 |
Rep 55
Can someone review my log?
Just want to make sure everything is how it should be I plan on tuning stage 1 soon. BTW I used MHD to log everything not sure how to link it?
06-21-2023, 05:07 PM | #3 |
recovering e36er
65
Rep 106
Drives: 2017 M240i Xdrive
Good to know, nice suggestion
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2 To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit |
07-04-2023, 06:22 PM | #4 | |
Rep 55
Anyways here's the logs, got some from last night. 2nd Gear Pull 3rd Gear Pull Thank you in advance ! This is my first turbo car so help would be greatly appreciated ! |
07-05-2023, 08:50 AM | #5 | |
Rep 1,198
Not sure if you car is a manual or auto but I recommend putting it in Sport or Sport+ mode to get a higher shift point.
2024 M2
2019 M240i- Sold |
07-05-2023, 12:14 PM | #6 | |
Rep 55
07-05-2023, 01:13 PM | #7 |
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
Realistically 3rd and 4th are what you want.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
07-05-2023, 03:08 PM | #8 |
Rep 55
Ok this is redline. please let me know if you see anything. I know timing is a little off on cylinder 1 but have no clue if it's fuel quality or something else. I changed my sparks plugs not too log ago so I know it's not that but still don't know.
07-06-2023, 08:26 AM | #9 | |
Rep 1,198
2024 M2
2019 M240i- Sold |
07-06-2023, 08:54 AM | #10 | |
Rep 55
07-06-2023, 09:58 AM | #11 | |
Rep 1,198
Check out one of my stage 2 logs. You will see zero timing corrections, and the throttle position stays at 98 through the pull. I believe I had 93 octane, and about 3 gallons of ethanol with the TU HPFP. https://datazap.me/u/jmclellan/aug-2...34-35-36-37-38
2024 M2
2019 M240i- Sold Last edited by JMcLellan; 07-06-2023 at 10:03 AM.. |
07-06-2023, 01:57 PM | #12 |
1296
Rep 3,533
Add a gallon of e85 and fill up with your 89 octane..
07-06-2023, 02:43 PM | #14 |
1296
Rep 3,533
Your 91 octane is basically 88/89 octane everywhere else.. its a jab and Californias crappy emissions control
07-06-2023, 02:44 PM | #15 | |
Rep 55
I'm going to add some E to my car today after filling up. |
07-06-2023, 03:00 PM | #17 |
1296
Rep 3,533
Yeah.. you can run about e30ish safely up to a certain boost level etc you'll be more than fine on stage 1 and even on stage 2 with mhd and bootmod3.. not so much 2+ and definitely not 2+ woth bootmod3.
RaddDroid713.50 |
07-06-2023, 03:25 PM | #19 |
1296
Rep 3,533
It's the way to go for sure!
RaddDroid713.50 |
07-06-2023, 11:05 PM | #20 |
Rep 55
Ok so I put 7.6 gallons of 91 with a gallon of E85
Here's the log The car definitely felt better, timing isn't as bad anymore but still getting throttle closure so unsure what to do now? Maybe because I'm overboosting(Peaked @ 19.6)? That's the only thing I can think of, this log has the highest PSI I ever recorded. Highest before this was 15-16 psi It was hot outside though and I'd been driving around to get the tank as low as possible (roughly 1 hour give or take) before I started logging. I'll give her one more pull later tonight when it's colder ! Last edited by RaddDroid7; 07-06-2023 at 11:27 PM.. |
07-07-2023, 08:16 AM | #21 | |
Rep 1,198
What map are you running??
2024 M2
2019 M240i- Sold |
07-07-2023, 10:54 AM | #22 |
Rep 55
