03-31-2017, 01:07 PM | #133 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
walnuttea39.00 |
03-31-2017, 03:20 PM | #134 |
Rep 424
Interesting I heard otherwise regarding the 245s on the 9.5". the Staggered factor wheels are what size, cant seem to find it online.
03-31-2017, 04:33 PM | #135 |
Rep 1,303
03-31-2017, 04:37 PM | #136 |
Rep 1,303
Oh and MPSS says it can go up to 9.5" I was mistaken: https://www.tirerack.com/tires/tires...omCompare1=yes
I still wouldn't do it personally. Pretty large stretch imo. |
03-31-2017, 09:36 PM | #137 | |
Rep 424
04-01-2017, 04:42 AM | #138 |
Rep 1,303
If you aren't tracking or doing hard cornering, you should be fine.
04-01-2017, 09:34 AM | #139 |
Rep 115
Thanks! I've been leaning towards getting these wheels for a while now. Keep going back and forth but might pull the trigger soon.
04-01-2017, 06:33 PM | #140 | |
Rep 424
I just ordered them staggered. I'll get some pics up once they are mounted.
04-02-2017, 05:28 AM | #141 | |
Reverse Homer
151
Rep 1,064
Standard would poke more then, correct? Ayye, decisions decisions lol |
04-02-2017, 05:44 AM | #142 | |
Reverse Homer
151
Rep 1,064
Did you do 18s staggered? I think I may go with 18s staggered too. Are you planning on using the stock rear tires for the front and buy new ones for the rear? |
04-02-2017, 08:07 AM | #143 |
Rep 1,303
Yes, one are machines 4mm front and rear and there's still some poke front and rear. However, if you were lowered on springs you'd clear in the front, but the back wouldn't clear. If you had coilovers and could give the back some nice camber then you'd clear the back as well. This is only for a 235/265 setup. A 225/255 setup would clear being on springs without issues.
Vyruz Reaper151.00 |
04-02-2017, 08:16 AM | #144 | |
Reverse Homer
151
Rep 1,064
So If i were to get the 18s - what type of tire setup should I go for, and can i use any of the stock tires? Maybe use the rears tires for the new 18x8.5 fronts? Sorry for the 21 questions lol |
04-02-2017, 08:17 AM | #145 | |
Rep 1,700
Will there be poke over the fender? What about 235's on the front? |
04-02-2017, 10:21 AM | #146 | |
Rep 1,303
04-02-2017, 10:24 AM | #147 | |
Rep 1,303
235s up front on et35x8.5 will poke about 5mm give or take. Machines to et39 you'll be basically flush (what I'm running) no issues at all. |
fbsm743.00 Mr Carrots766.50 |
04-02-2017, 01:02 PM | #148 | |
Rep 1,700
On stock springs with the 19's and ~1cm of poke are you running into wheel well/fender rub? How about on lowered? |
04-02-2017, 03:17 PM | #149 | |
Rep 424
I'm in Richmond. I work in San Rafael but it's generally too late when I'm off to enjoy those Marin windy roads. As for the set up I'm going with 18s staggered and staying with my stock tires probably for another 5k miles till I replace all tires. But I only have 8k on the car.
04-02-2017, 06:05 PM | #150 |
Rep 1,303
Absolutely zero rubbing on stock suspension. I'm not lowering because of the MP splitter, but I have compressed the rear enough to see that if lowered it would hit the fender with stock camber settings. You'd need 255s or coilovers for additional camber to avoid rubbing when lowered. The two shots below are the passenger side rear wheel 19x9.5et44 with 265/30 DWS06 all seasons under compression (really unlevel section I parked on). 255 would be more of a stretch so would definitely clear the fender.
fbsm743.00 |
04-02-2017, 06:11 PM | #151 |
Rep 1,303
Here's the front driver side (picture taken same time the rear pictures were taken). Again, fronts are 235/35 19x8.5et39 DWS06 all seasons.
04-02-2017, 06:16 PM | #152 |
Rep 1,303
With those pictures in mind, a 245 up front would probably fit with stock suspension, but would need camber if lowering.
Also, did a nice run with some guys from cars and coffee today through some hills and twisters here in Germany (Ramstein to Johannesburg) and had zero issues with rubbing and the grip was phenominal. Car was planted the whole time with tons of confidence it'd stay like that when pushing it through the turns at high speeds. |
hoppy6698127.00 |
04-03-2017, 08:36 AM | #153 | |
Rep 1,700
Joe2402925.00 |
