02-13-2019, 07:03 PM | #551 |
Rep 525
710FF 19x8.5 et45, 19x9.5et45. It's the 8.5's that aren't in yet.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
02-13-2019, 07:09 PM | #552 |
In search of the perfect cup of coffee
152
Rep 213
02-14-2019, 10:06 AM | #554 |
General
2051
Rep 25,989
Shoot me a PM with your order details and I can definitely look into that for you!
VMR|Wheels | 714.442.7916 |
02-14-2019, 10:22 AM | #555 |
Rep 13
2016 M235i - No suspension mods - I'm the 2nd owner of the car and car came with square 18" 7.5 436M rims. I guess the previous owner liked the idea of rotating his tires.
Am I safe to run V703 18X8.5 +35 Front and 18X9.5 +45 Rear without my car's abs/electrical system freaking out? Will run a 225/40/18 Front and 255/35/18 Rear It seems this is the correct fitment based on all the pics and info in this thread. New to the forum so thanks for any help! |
02-14-2019, 10:34 AM | #556 | |
General
2051
Rep 25,989
Yes, these specs are what we generally recommend for the M235i. I'll shoot you a PM with some pricing. I have these available in Super Silver and Gunmetal!
02-14-2019, 04:04 PM | #558 |
Rep 525
PM/email sent. Thank you for looking into this.
02-17-2019, 08:53 AM | #560 |
DisplacementReplacement
438
Rep 1,130
After reading this several times I still feel the need for clarification on the following set up.
2015 M235 XI - will the following be ok??? with fitment/rubbing??? I don't want to use spacers... 18x8.5 ET35 - 235/40 18 18x9.5 ET45 -265/35 18 Dinan springs Thanks in advance.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
02-17-2019, 09:01 AM | #561 | |
Rep 525
8.5 ET35 with 235's will most likely rub on springs 8.5 ET45 with 235's are very close to the strut. Others have reported success with a 3mm spacer giving you an effective ET42. This is what I plan on doing. If you want 235's, find a 8.5 ET 40-42 or go ET45 with 3mm spacers. If neither of those work, go with 225's.
02-17-2019, 09:15 AM | #562 |
438
Rep 1,130
Thanks for reply.........
There are two issues i'm trying to avoid. 1) reported issues with spacers causing drivability issues like vibrations. I've seen this first hand and read about it so it's a real. 2) also, i prefer the look of the 235 in the front, seems to fill out the wheel well nicely. Thoughts?
02-17-2019, 11:19 PM | #563 | |
Rep 2,601
ET35 will be further from the strut/springs than ET40-42. |
02-18-2019, 04:35 PM | #565 |
Rep 3,506
Do you know why the spacers involved caused vibrations? I ask because I've used spacers quite a bit and have never had an issue with them.
02-18-2019, 07:40 PM | #566 | |
Rep 2,601
I agree that ET40 is probably a safer bet if you have less camber. |
NOT2DAY117.00 |
02-19-2019, 10:34 AM | #567 | |
Rep 124
With camber plates of course, your selection in wheels and tires becomes much wider as you can increase the amount of rubber up front. |
Nugget649.50 |
02-19-2019, 05:17 PM | #568 | |
General
2051
Rep 25,989
As far as spacers are concerned, running a 3mm hub centric spacer shouldn't cause any issues with vibration as there's still plenty of hub engagement there. Fun fact: some OEM's even offer spacers as a factory option.
02-19-2019, 05:20 PM | #569 |
General
2051
Rep 25,989
Let me know if you have any questions on pricing or fitment! Happy to help!
02-20-2019, 11:57 PM | #570 |
Rep 144
19s
overcoil3081.00 shovell24237.50 |
02-24-2019, 12:52 PM | #571 |
Rep 5
Hello there. I recently bought a brand new 2019 230i M Sport, and it was delivered on winter tires - so it is now time to order a new set of wheels for the summer. I've been going through the thread and it seems that these are the specs to go for:
F: 8.5" ET35 225/35/19 R: 9.5" ET45 255/30/19 This is the "plug and play" size, right? The specs for M235i and M240i are the same for the non-M cars I take it. Would going for 18s instead lower the risk of rubbing? My car's suspension will remain stock for as long as I own it, and I wanna avoid rubbing at all cost. |
02-25-2019, 11:29 AM | #572 | |
General
2051
Rep 25,989
Tags |
9.5, fitment, v703, vmr, wheels |
