06-24-2014, 04:07 PM | #1 |
Rep 659
Kicker Substation added to HK Audio System
Like many of you I was very disappointed with the lack of bass in the HK audio system. I worked with La Jolla Audio here in SD to come with a solution that would maintain 100% factory functionality and maintain a reasonable amount of trunk space while providing the low end grunt that the system needs.
I was presented with a few options such a custom corner enclosure (way out of my budget until a 3rd party company mass produces a solution) and upgrading the subs under the seats (they only promised a 20-25% gain in bass) which was also pricey. They then introduced me to Kicker's 10" Substation which is modular solution so if I ever needed 100% of my trunk it can easily be removed. This option was almost half the cost of the custom enclosure route so I decided to give it go. Installation: I do not have too much information regarding this but I will share what I know. The parts used were as follows: Drain Limiting Circuit, Audiocontrol LC2i Factory Amp Interface, Kicker Substation and the woofer grill. They told me that they would be tapping into the one of the under seat woofers to get the signal, I'm assuming by tapping into the line from the amp itself. The sub itself mounted to the floor using a bracket. Lowering the rear seat will allow removal of the enclosure. All of the wiring, including the power cable, can be removed via quick release clips. The Substation independent volume control was installed beneath the dash to the right of the steering wheel (pic below). Control/Operation: Pretty straight forward. Volume knob controls the sub volume and the bass control on the I-Drive will adjust bass on the the factory system and the Substation. They recommended that I do not go above 60% bass (depending on the type of music) as this would just add noise to the system. Sound: This solution definitely adds the lower frequency that this car is lacking. It can shake the car depending on the music and being able to adjust the volume helps with different types of music. Also, now that I don't have to have the bass turned all the way up it allows the HK speakers to really sing. Criticism: If I had to gripe about this solution it would that it's not the most visually appealing but I'm not sitting in parking lots blasting my music with the trunk open and the mid range now seems to be lacking a bit. Overall this was a definite improvement and probably more than what is needed but the independent control allows you to dial in as much as you desire. The modularity of the system is a huge win for me. I may look into a corner mount solution once an "off the shelf" enclosure becomes available but until then this will do the job.
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
06-24-2014, 08:13 PM | #5 | |
Rep 418
Don't get me wrong..both the mids and bottom of the stereo need help, but the mids affect more of the music that's being heard. Maybe popping in a pair of Focals or other high-end speakers will get the midrange into a better space for you. good luck! |
06-25-2014, 01:52 PM | #6 | |
Rep 659
Much appreciated!
F97 X3M
06-25-2014, 04:40 PM | #7 | |
Rep 418
FYI...Transducers like mics and speakers are typically the most important piece in the audio chain and should provide the biggest bang for your buck. I always start by upgrading these stock components and see where things set after that. If you want to goose the power afterwards, you can see what amps are out there. Either way you'll feel secure that you haven't wasted any money by replacing the stock speakers. Good luck! |
06-25-2014, 05:50 PM | #8 | |
Rep 659
Much appreciated!
F97 X3M
06-25-2014, 06:13 PM | #9 | |
Rep 1,756
06-26-2014, 09:01 AM | #10 |
Rep 855
Why spend $875 dollars on a system just to replace the biggest part of it? I disagree with Steven1077 here. No, speakers are not going to make your low end system sound like a high end system, but if you are going to upgrade one piece of a system to get the absolute maximum sound quality out of it, the speakers are that one piece!
06-26-2014, 11:39 AM | #12 | |
Rep 418
However, the single biggest piece impacting audio chain is typically the transducer…the thing converting one kind of energy to another. (Speaker, turntable stylus, microphone, cassette deck, etc.). These are typically at the ends of an audio chain. With rare exception, you can put a great amp, and excellent cables in front of average speakers and get minimal improvement. Replace average speaker with great speakers and connect them to an average amp and cables and you will almost always hear significant improvement. A great system should always start with great transducers. They convert the energy... Think engine for horsepower Think tires for handling |
08-21-2014, 11:28 PM | #13 | |
Rep 765
09-22-2014, 12:35 PM | #15 |
Rep 659
Installer told me that they tapped into the wires running to the under-seat subs. Please post some pics of your set up once completed!
F97 X3M
