2Addicts | BMW 2-Series forum Classifieds Members Classifieds Engine / Drivetrain / Exhaust / Bolt-ons XDI 35 N55 - Used
      06-03-2023, 02:39 PM   #1
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
XDI 35 N55 - Used
For sale is my XDI35 HPFP replacement for the BMW N55. Had this installed on my M2 for about 30,000 miles with no issues.
I tested this with both BM3 and MHD tunes with no issues, so you can use either.
I went ahead and ordered a full set of new bolts/ hardware which I am including as well as a new connection adapter for earlier cars that do not have the newer HPFP connector. Also including the HPFP connector replacement that you had to splice in (before they came out with the adapter) that was installed on my car if you prefer to go this route.
Link to Item
NOTE: this pump is from before the revision was made to address a known issue sometimes seen on these where there is an intermittent chirp noise when the car idles and is under lighter load. I did notice it at times but but often. This does not interfere at all with performance, can just be a little annoying.
I was quoted $200 by the manufacturer to fix this issue so I left it as is. BUT, if you are interested, I can have this fix done for a $200 non refundable (in case you decide to back out) deposit on top of the purchase price.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
