12-31-2020, 06:23 AM | #1 |
Rep 51
New BMW fan! Looking for advices for my f23
Hi guys!
I'm looking for your opinions/recommendations on my BMWf23 220i (2019) please. Well, I got my ECU remapped and the hp/torque gain is pretty impressive on the B48 engine. I got the shorter antenna as well that's all so far for cosmetics. I'm on 17" wheels and considering putting some 18" but would this affect the acceleration? Also, I wanted to upgrade the head unit display but all I see on the market its China-made products which doubtfully any good quality? I was considering sway bars are they worth it? And also is there a way to put bigger brakes let's say from m2 on my 220i? Let me know please! |
12-31-2020, 09:12 AM | #2 | |
Rep 970
TheMadVlad7.00 |
12-31-2020, 09:52 AM | #3 | |||
Rep 51
I'd probably just repaint my 17" wheels in glossy black to match the front grill color! Since its just 220i (even chipped) Id hate to loose the acceleration or torque moments (I love drifting or cornering a bit in the Spain mountains) |
01-01-2021, 12:05 PM | #4 | |
Rep 1,602
Also, if you're looking to maybe fit some bigger brakes on there in the future, you may need bigger wheels just for clearance. I'm fairly sure M2 brakes won't fit under 17's. I guess what i'm saying is that if you like the look of 18-inch wheels, just go for it. It's one inch bigger. If you were going for like 20-inch wheels....you might want to think about penalties to acceleration and handling. But 18's? I think you'll be fine. |
01-02-2021, 07:18 AM | #5 |
Rep 527
Ok I get that you want to spend money on your car, but these changes are mostly not going to help. Maybe the roads in Spain have no potholes and the bigger wheels will not increase the risk of damage, never been there. Your car has very good brakes, are they causing problems? The sway bar might be helpful, my 230 does understeer. And keeping fresh tires on it will be money well spent.
01-02-2021, 01:52 PM | #6 | |
Rep 1,602
https://www.autocar.co.uk/opinion/an...ecome-disgrace |
01-05-2021, 12:55 PM | #7 | |
Rep 51
Currently, I have BMW LA Wheel, M Double Spoke 460... I just checked they are about 1700 euro in Europe. I was quite surprised, to be honest, as I thought it would be the most basic BMW rims fitted. So probably if I'd go for some high-quality 18", it would be in the 3k euro region at least, which is kinda too much for me. |
01-05-2021, 01:01 PM | #8 | |
Rep 51
The brakes ain't causing any problems, but you know we always want something a little bit better. The M brakes look very solid. I'm still trying to figure out if it can be fitted on 220i with 18" rims and if it's worth all the headache and money from the performance side. |
01-05-2021, 01:03 PM | #9 | |
Rep 51
01-05-2021, 01:22 PM | #11 |
Rep 51
I really want to upgrade this small "business" navigation unit to a larger "professional" unit. Mine comes without Apple Carplay even...
BMW Evo NBT ID5 would be around 1200-1400 euro, but I'm definitely going for it. IF anyone had the experience of upgrading the unit, please share your knowledge! |
01-05-2021, 02:41 PM | #12 |
Rep 1,602
I actually really like those 17's and of course i'm biased, but I love the blacked out grille look on the 2-series. The whole color scheme works really well with the black roof.
I like the newer i-drive unit that came on my car but i wouldn't say its amazing or anything. Apple CarPlay lags a bit because its wireless. Its still totally usable and all, but that aspect is a little annoying. It also doesn't display Apple CarPlay as a full screen, though i'm pretty sure that's something that can be fixed in the aftermarket. Anyway, good luck with your planned modifications! |
01-06-2021, 04:56 AM | #13 | |
Rep 51
I like these small touches Thank you Moflow, ill keep my thread running with my progress, maybe someone would find it helpful! |
Moflow2484.50 |
01-06-2021, 10:19 AM | #14 | |
Rep 970
Go to the Tire Rack website and start comparing rims and tires (they list weights for every tire and wheel. I found the Enkei RPF1's to be the lightest and they come in black if you like. Search out the different tries to find the lightest with the best wear rating. I have Conti Extremes on mine (but they are the older version - newer ones weigh 1 lb more. Pirelli has some light weight options that should be a good match to the wheels. If you drop 8 lbs for each tire/wheel, you should get the same results in performance and handling I did. |
01-06-2021, 11:07 AM | #15 | |
Rep 2,200
https://www.2addicts.com/forums/show....php?t=1253651 https://www.2addicts.com/forums/forumdisplay.php?f=520 https://f30.bimmerpost.com/forums/fo...play.php?f=426
01-06-2021, 02:36 PM | #16 | |
Rep 51
thank you, USA-RET. I'm going to research on their website! I'll run the numbers, maybe I'd get the 18" and sell my 17" or leave them as spare (no winter wheels needed since I'm in the south of Spain) P.S oh... they don't have bmw 220i model in their website it's starts from 230i... Last edited by TheMadVlad; 01-06-2021 at 02:57 PM.. |
01-06-2021, 02:41 PM | #17 | |
Rep 51
Tons of useful information...I'm watching youtube videos as well about NBT Evo. Per my understanding, there is a main unit and the screen. Could it be my main unit is fine and modern (NBT EVO ID 5 or 6)... still trying to figure it out.... I might just buy the bigger screen and it's plug and play scheme basically. |
01-07-2021, 09:10 AM | #18 | |
Rep 970
I have friends that spend hundred$ on a performance part (like a cold air intakes) that will render a modest bump in HP only to swap to heavier wheels and erase that gain. They value looks over performance which is fine if that's what you want. F1 teams spend thousand$ to get the lightest wheels they can to get a leg up on the competition. McLaren ran Enkei wheels for a few season a while back. https://duckduckgo.com/?q=.+McLaren+...tok%3D9S0vVVOD I ordered my tire and wheel combo from Tire Rack as a package. When I take delivery of my new Mini, I take the stock wheels/tire off and store them until I'm ready to trade the car in and replace them with my Enkei set. I could have saved even more weight if I went down to 16" wheels. Personally, I would never spend the money to go bigger unless you go with a CF set (and even then a smaller CF wheel will weigh less that a larger one). https://www.svtperformance.com/threa...rmance.613551/ https://grassrootsmotorsports.com/ar...really-better/ http://www.tuneruniversity.com/blog/...t-people-down/ Although I cannot find the link now, there was test of a Camaro with 3 different wheel/Tire set ups. They dyno'ed the car with the different sets and coincidentally, the tire/wheel set that reduced the unsprung weight by 32 lbs yielded the 9WHP and 9WTQ gains I mentioned earlier. The heavier wheels stole WHP and TQ. Just my $.02 |
E46ZHP254.00 |
01-08-2021, 04:44 AM | #19 | |
Rep 51
I researched, and Enkei's RPF1 would be hard to beat by price/weight ratio. My current rims, M Double Spoke 460 - are about 22.5 lbs each. The RPF1 17" - are about 15 lbs per rim, so only rims would save 30 lbs given they are the same size. However, I can't get the RPF1 with 5 x 120 PCD; they don't produce them. Now, if I want to upgrade my brakes, I'd personally go with a BMW performance brake kit (they do fit f23 220i) https://www.ecstuning.com/b-genuine-...o/34112450470/ But of course, I'd need 18" rims to fit them up. So the question is, the performance brake kit is really worth it over my standard brakes? That leaves me with a few options: 1) Getting Enkei's RPF1 18" 5x120 set and adding the M performance brake kit. 2)Getting lightweight 17" and leave my standard brakes. 3) Repainting my Double Spoke 460 to glossy black to match the car color pattern. |
01-09-2021, 09:32 AM | #21 | |
Rep 970
https://www.tirerack.com/tires/tires...unflat%20Tires https://www.tirerack.com/tires/Spec....=Runflat+Tires Did a quick search and this is the lightest combo I found in 17" for your car. Stock BMW wheels are quite heavy in comparison and I would assume the tires on your car are at least 21 lbs each, and probably a bit more. Finding actual weight online can take some time. Tire Rack shows original equipment tires: https://www.tirerack.com/tires/TireS...inLoadRating=S If your stock tires weigh 21 (they could be 22 or even 24lbs depending on the brand actually on your car) and your wheels 22.5, the tire ( 18lbs) and wheel (16.4lbs) combo above would save you 36 lbs overall (6.1 lbs lighter per wheel and 3lbs lighter per tire). TPMS is a wash and doesn't factor in. |
01-10-2021, 05:36 AM | #22 | |
Rep 51
I'm running Bridgestone Potenza S001 RFT 225/45 R17 91W on the front and Potenza S001 RFT 245/40 R17 91W on the rear. Potenza S001 RFT 225/45 R17 91W - 24.5 lbs - 10.88 kg Potenza S001 RFT 245/40 R17 91W - 26 lbs - 11.79 kg Last edited by TheMadVlad; 01-10-2021 at 05:54 AM.. |
Moflow2484.50 |
