10-12-2018, 07:24 AM | #1 |
Rep 2,873
Dealer says can't read fault codes from last week?
Posted details in the N20 section, but hoping to get more input on this aspect - dealership says they can't read any details of the 'drivetrain malfunction' warning/limp mode from this weekend, because "I've started it several times, and that will have wiped all the old codes". Check engine was lit, but not now. It is driving fine now, but this has happened 3 times, and I'd like to find out why.
I appreciate that most will be skeptical, as am I, but really seeking input from some of you out there with firm tech knowledge. If dealership holds to this line, what are my options to move up the tech 'food chain' for a better answer? FWIW, Mike Miller thinks it may be a soft battery. |
10-12-2018, 04:10 PM | #2 |
Rep 5,372
Buy an OBDII reader, preferably one that can read all BMW codes, and then you can read all the codes as soon as they appear. I've got the Torque App which is only $5, but there are some specific BMW codes it can't read or even pick up. Something like Carly (https://www.mycarly.com/) should allow you to read all codes.
The fact that the codes are coming on and off is a little bizarre, but if they don't stay on, there's not much BMW can do if they are aren't being held in the memory. By reading the codes yourself, you can tell BMW the code ID numbers and from there they can start pinpointing the specific system causing the issue(s).
Maynard3848.00 |
10-13-2018, 02:12 PM | #3 |
Rep 558
And, Carly allows you to save a full scan report as a pdf. It's very nice. I have their proprietary bluetooth adapter and full pro app for Android. I've been very pleased with it.
Maynard3848.00 |
