10-04-2018, 10:58 AM | #1 |
Rep 71
Tire rack recommended 17” winter package?
Hi guys,
I know very little about tires and winter set up causes I’ve always driven a winter beater (Jeep) but my Jeep is no more. I have a stock 2017 M240i xdrive and am looking to put on the Michelin X-Ice XI3s. Tire rack gives me a suggested tire wheel package of X-Ice 225/45r17 with MSW Type 22 17x7.5 rims. Obviously there’s guaranteed fitment with Tire Rack but I just wanna be sure: will there be any rubbing with M performance brakes? Any other concerns I should be aware of? I greatly appreciate any help on this. |
10-07-2018, 03:55 PM | #3 |
Rep 442
Offset?
You also want to check the Offset of the rims.
Ideally for a 7.5" width, you would be near the stock offset of 45. In the range of 40-45 is good. I went with a Tire Rack suggested package also, with MSW 55. They fit, with no rubbing, but the offset on these is 32, and they 'poke' a lot more than I would like. The tires barely clear, and the offset is far enough from stock that I occasionally get some odd tracking/tramlining from them. If I had thought it through better I would not have bought these. You also want to make sure the wheels do NOT need a centering ring or different lug bolts. There are enough wheels that fit BMW with stock bore and bolts that it's not worth the hassle of dealing with wheels that need extra parts to fit. Especially with winters. Ask Tire Rack about this before ordering. The stock Center Bore for F22 wheels is 72.56mm, often listed as 72.6mm. |
10-07-2018, 08:18 PM | #4 |
Rep 407
I have Conti WinterContact SI tyres on TRM C4 and have had no problems, never got stuck. Also no damage apparent from last years winter through WNY.
17x8 et40 and fit with no modifications. Conti's because they are highly rated and they had good discounts going on. |
10-08-2018, 09:36 AM | #5 | |
Rep 233
Drives: '18 M2 LCI
'18 M2 LCI 6spd
10-09-2018, 07:07 AM | #6 |
Rep 71
Just bought the tire/wheel package with Michelin xIce 225/45R17 and the TRM C4 17x8 (40 offset). According to tire rack should reuse OEM hardware. Will post results once they’re on. Appreciate the help guys!
10-10-2018, 09:47 AM | #7 | |
Rep 57
10-11-2018, 06:06 AM | #8 | |
Rep 407
I ran another style of TRM wheels on my old E30 (albeit 15x8") for several years without an issue. |
