09-14-2018, 04:37 PM | #1 |
Rep 57
228i/230i 17" wheels on M240i?
Looking to put together a set of 17" winters for my M240i and am having a hard time determining if certain other OEM BMW wheels will fit the uncommon offset on the M240i and avoid rubbing, etc, so was thinking of keeping it simple and getting 17" wheels from a 228i or 230i. Would any 17" wheel from those cars fit an M240i?
thanks! |
09-15-2018, 09:23 AM | #2 | |
NewFinishColumbia/detailer
604
Rep 2,096
09-15-2018, 09:32 AM | #3 |
604
Rep 2,096
OEM 17" Winter M-Sport Wheels and Tires https://www.2addicts.com/forums/show....php?t=1500329
Found the link.
09-20-2018, 03:21 PM | #5 |
Rep 8,942
BBS SR or SX will fit, are less money and a better quality wheel.
09-20-2018, 05:51 PM | #6 |
3621
Rep 3,590
Bear in mind though that the BBS wheels aren't designed for performance use from a weight perspective, as they are some of the heaviest wheels out there at 11.8kg / 26lbs for the SR and 13.2kg / 29lbs for the SX in 18x8 size compared with, for example the OEM 461 wheel at 11.2kg / 25lbs in 18x8 size (which is also on the heavy side for that size of wheel).
These are the BBS economy cast wheel, engineered to a price, but should work fine for winter tyres. |
09-20-2018, 07:17 PM | #7 | |
Rep 8,942
18" yeah you've got a lot more options but that wasn't what OP was interested in. I run 18" Apex for example.
10-01-2018, 01:23 PM | #8 |
Rep 129
I just tested OEM 17" star spoke 394 style 225/50/17 7.5 ET37 (came off F30 328 with non-M-Sport brakes.) on my m240i. Fits fine-not the prettiest rims for a 2er, but should work well for winter. I will replace the rubber with 225/45/17 this winter.
Hope this helps. |
10-02-2018, 12:06 PM | #9 | |
Rep 57
