08-26-2018, 11:17 AM | #1 |
Rep 558
18x8.5 ET38 & 255/35 Rear - Rub?
I have a set of 18x8.5 ET38 wheels and want to put 255/35 A/S 3+ tires on them on the rear of my M240i (stock suspension).
I'm planning on getting an alignment after install and willing to go up to -2 degrees camber in the rear. It's currently at -1.25 degrees. Using the wheel calculator, I know they will poke: https://www.wheel-size.com/calc/?whe...cl=25mm&sr=0mm I'm not happy that they will poke, but I am willing to accept that as long as they don't rub. I don't want to buy and install the tires before I am confident they won't rub. Is there anyone that has this fitment on the rear of a 2 with stock suspension and can confirm they don't rub? Thanks!
08-27-2018, 10:17 AM | #2 |
Rep 1,369
You won't poke. I'm on Dinan springs, running 18x9.5 ET 58 with 5 mm spacers and 255 PSS and have a good 5mm before being flush. No issues at all. 18x8.5 ET 38 will be 2.3 mm further out than my setup. Should look good. Plus, 255 A/S should be a bit narrower than Pilot Super Sports.
08-27-2018, 11:24 AM | #3 | |
Rep 558
But, using this wheel calculator, I come up with different amounts. It looks like using your fitment (including spacer), the tires would only stick out 4mm more than stock: https://www.wheel-size.com/calc/?whe...cl=25mm&sr=0mm But, using my fitment, the tires would stick out 19mm more than stock: https://www.wheel-size.com/calc/?whe...cl=25mm&sr=0mm 19mm (3/4in.) more than stock is quite a bit. That's why I am reluctant to buy and mount the tires before someone confirms they've tried this fitment and it doesn't rub.
08-28-2018, 09:10 AM | #4 |
Rep 61
Sorry, I don't have the same setup as you so you will have to make a judgement call as to whether the following helps you.
My rear is a 265/30R19 9" ET40. (Front is 235/35R19 8" ET35) I stick out 22mm more than stock. You stick out 19mm. I am 2mm further away from suspension than stock, you are 9mm. My wheel fills the wheel well by an extra 7mm, yours, 3mm. So, I am 7mm closer to the suspension, 3mm further out and 4mm larger total radius than you. With stock suspension. I have never had any rubbing. I tested it on the track for the first time this weekend and had zero issues. You will poke a little, but very close to flush. I don't think you will rub. I put some pictures in this thread for reference. https://www.2addicts.com/forums/show...1372250&page=3 |
PeterWT253.50 |
08-28-2018, 10:11 AM | #5 | |
Rep 558
That was very helpful. Thank you! Edit: Your front fitment is also a few mm larger diameter and sticks out a few mm more than my planned fitment in the front. So, this is reassuring as well. Thanks again!
08-28-2018, 11:49 AM | #6 |
Rep 42
i have the set up as you mentioned and it does stick out a bit. no rubbing but 255 also seems too big for the 8.5. I didn't like it and swap the rear out to a 9. here's how it looks like. hope this helps.
PeterWT253.50 |
08-28-2018, 12:13 PM | #7 | |
Rep 558
Is that picture with the 8.5in wheel, or the 9in? If it's the 9in, what's the offset? Thanks.
08-29-2018, 10:25 AM | #8 |
Rep 42
that's the 8.5 wheel with 255 PS4S. i have to add that the car is on stock suspension and is not lowered in anyway.
08-29-2018, 06:07 PM | #9 |
Rep 558
OK, thanks for the follow up.
10-07-2018, 08:17 PM | #11 |
Rep 558
My OE PSS still have some tread left on them, so I haven't put the new wheels/tires on yet... They're sitting in my garage, mounted, waxed and waiting.
The fronts are the same wheels, but with 235/40/18 A/S 3+ on them. I'm worried that those might also rub. We'll see...
11-04-2018, 05:30 PM | #12 |
Rep 558
Well, I finally put them on the car.
4x (front & rear) 18x8.5 ET38. Michelin PS A/S 3+, 235/40 front & 255/35 rear. They don't rub!
11-21-2018, 05:55 PM | #13 |
Rep 55
11-22-2018, 02:13 PM | #14 |
Rep 558
Sidewall pokes slightly, but the tread is just tucked under the fender lip. You can see a picture here:
https://www.2addicts.com/forums/show...&postcount=257 The ideal wheel and tire specs for this car (for me) would be: Front: 18x8 ET42, 235/40 Rear: 18x9 ET50, 255/35
jooksingjai7710.50 |
